04-14-2012, 13:05 | #9 (permalink) |
Registered User Join Date: May 2010
Member: 1295985 Status: Offline Thanks Meter: 86 | Bus check: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: Using device: HTI, FW ver: 00.50, SN: 00002729 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1C600018FF976C561558FD7EFF82DB48740CEDA3 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 TransmissionMode: DDR&TX2 Selected firmware certificate matched. Original Imei: 35953701399672 Original Product code: 0554412 Bluetooth ID: 001E3A33DFF8 SIMLOCK PA identifier: [0] PA_SL Phone type: RM-217 (Nokia 6300) SW version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35953701399672-1 Product code: 0554412 Battery voltage: 4807 mV, current: 67 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359537013996721 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
04-14-2012, 13:17 | #10 (permalink) | |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | Quote:
1-repair super sd 2- load pm full or modified its urs own choice 3-repair sd auth 4-pm auth 5-write pm thats all | |
04-14-2012, 13:18 | #11 (permalink) |
Member: 1295985 Status: Offline Thanks Meter: 86 | Self tests: Phone Type: RM-217 SW version: V 07.30 07-05-09 RM-217 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N !no signal 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N !FAILED(01) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
04-14-2012, 13:42 | #12 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2011 Location: APPEL
Member: 1707492 Status: Offline Thanks Meter: 606 | Quote:
04-14-2012, 13:59 | #13 (permalink) | |
Member: 1295985 Status: Offline Thanks Meter: 86 | Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: Using device: HTI, FW ver: 00.50, SN: Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) Phone type: RM-217 (Nokia 6300) SW version: V 07.30 07-05-09 RM-217 (c) Nokia. Using cached productData. PUBLIC ID: 1C600018FF976C561558FD7EFF82DB48740CEDA3 PRIVATE ID: 2C9933700CE16E8613FC8C254093345732D23EDA Updating SUPERDONGLE_KEY ...OK Authenticating to SUPERDONGLE ... SUPERDONGLE authorized ! Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\6300_RM-217.txt ... Writing RF settings to phone ...OK, finished. 12 Records found. Writing BB settings to phone ...OK, finished. 9 Records found. Done. Phone authenticated to SUPERDONGLE already. Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 29 (6 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 2 - Key: 0, size 432 bytes written. Section: 4 - Key: 0, size 1 byte written. - Key: 1, size 60 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 16 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 11, size 1 byte written. - Key: 12, size 1 byte written. - Key: 13, size 1 byte written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 1 byte written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 16 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 byte written. - Key: 1, size 2 bytes written. - Key: 2, size 1 byte written. - Key: 3, size 2 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 2 bytes written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 byte written. - Key: 14, size 1 byte written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 1 byte written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 21, size 1 byte written. - Key: 22, size 1 byte written. - Key: 23, size 1 byte written. - Key: 24, size 1 byte written. - Key: 25, size 2 bytes written. - Key: 26, size 1 byte written. - Key: 27, size 1 byte written. - Key: 28, size 1 byte written. - Key: 29, size 1 byte written. - Key: 30, size 1 byte written. - Key: 31, size 1 byte written. - Key: 32, size 1 byte written. - Key: 33, size 1 byte written. - Key: 34, size 1 byte written. - Key: 35, size 1 byte written. - Key: 36, size 1 byte written. - Key: 37, size 4 bytes written. - Key: 38, size 1 byte written. - Key: 39, size 1 byte written. - Key: 40, size 1 byte written. - Key: 41, size 1 byte written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 byte written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 byte written. - Key: 48, size 4 bytes written. - Key: 49, size 1 byte written. - Key: 50, size 1 byte written. - Key: 51, size 1 byte written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 byte written. - Key: 56, size 1 byte written. - Key: 57, size 1 byte written. - Key: 58, size 2 bytes written. - Key: 59, size 1 byte written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 byte written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 byte written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 byte written. - Key: 69, size 1 byte written. - Key: 70, size 1 byte written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 byte written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 byte written. - Key: 79, size 1 byte written. - Key: 80, size 1 byte written. - Key: 81, size 1 byte written. - Key: 82, size 1 byte written. - Key: 83, size 2 bytes written. - Key: 84, size 1 byte written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 byte written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 byte written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 byte written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 byte written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 byte written. - Key: 116, size 1 byte written. - Key: 117, size 1 byte written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 byte written. - Key: 121, size 1 byte written. - Key: 122, size 1 byte written. - Key: 123, size 8 bytes written. - Key: 124, size 1 byte written. - Key: 125, size 1 byte written. - Key: 126, size 1 byte written. - Key: 127, size 1 byte written. - Key: 128, size 1 byte written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 byte written. - Key: 132, size 1 byte written. - Key: 133, size 2 bytes written. - Key: 134, size 1 byte written. - Key: 135, size 2 bytes written. - Key: 136, size 1 byte written. - Key: 137, size 1 byte written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 byte written. - Key: 141, size 1 byte written. - Key: 142, size 1 byte written. - Key: 143, size 1 byte written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 byte written. - Key: 149, size 1 byte written. - Key: 150, size 1 byte written. - Key: 151, size 1 byte written. - Key: 152, size 1 byte written. - Key: 153, size 1 byte written. - Key: 154, size 1 byte written. - Key: 155, size 1 byte written. - Key: 156, size 1 byte written. - Key: 157, size 1 byte written. - Key: 158, size 1 byte written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 byte written. - Key: 162, size 1 byte written. - Key: 163, size 1 byte written. - Key: 164, size 1 byte written. - Key: 165, size 1 byte written. - Key: 166, size 1 byte written. - Key: 167, size 8 bytes written. - Key: 168, size 4 bytes written. - Key: 169, size 1 byte written. - Key: 170, size 1 byte written. - Key: 171, size 1 byte written. - Key: 172, size 1 byte written. - Key: 173, size 1 byte written. - Key: 174, size 1 byte written. - Key: 175, size 1 byte written. Section: 31 - Key: 4, size 12 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. Section: 43 - Key: 5, size 4 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 80 bytes written. - Key: 1, size 2 bytes written. Section: 56 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. Section: 66 - Key: 0, size 160 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 1 byte written. - Key: 3, size 1 byte written. - Key: 4, size 160 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 160 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 1 byte written. - Key: 12, size 2 bytes written. - Key: 14, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 64, size 8 bytes written. - Key: 65, size 8 bytes written. - Key: 66, size 8 bytes written. - Key: 70, size 8 bytes written. - Key: 86, size 12016 bytes written. - Key: 104, size 19 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 2 bytes written. - Key: 118, size 2 bytes written. - Key: 120, size 2 bytes written. Section: 67 - Key: 0, size 1756 bytes written. Section: 76 - Key: 0, size 534 bytes written. Section: 84 - Key: 0, size 3 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 byte written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 19, size 40 bytes written. Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 163 - Key: 0, size 8 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. - Key: 2, size 1 byte written. Section: 182 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 183 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 184 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 185 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 186 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 187 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 188 - Key: 0, size 1 byte written. - Key: 1, size 1 byte written. - Key: 2, size 1 byte written. - Key: 3, size 8 bytes written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 1 byte written. - Key: 10, size 1 byte written. - Key: 13, size 8 bytes written. - Key: 17, size 1 byte written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 byte written. - Key: 22, size 8 bytes written. - Key: 23, size 1 byte written. - Key: 25, size 1 byte written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 5 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 202 - Key: 4, size 42 bytes written. Section: 213 - Key: 0, size 20 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 232 - Key: 0, size 20 bytes written. - Key: 1, size 1 byte written. - Key: 3, size 1 byte written. - Key: 4, size 1 byte written. - Key: 5, size 1 byte written. - Key: 6, size 1 byte written. - Key: 7, size 1 byte written. - Key: 8, size 1 byte written. - Key: 9, size 4 bytes written. - Key: 10, size 1 byte written. Section: 238 - Key: 1, size 1 byte written. Section: 250 - Key: 1, size 1080 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 388 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. - Key: 21, size 40 bytes written. - Key: 22, size 40 bytes written. - 308 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 319 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. - Key: 19, size 148 bytes written. - Key: 20, size 148 bytes written. - Key: 21, size 148 bytes written. - Key: 22, size 148 bytes written. - Key: 23, size 148 bytes written. - Key: 24, size 148 bytes written. - Key: 25, size 148 bytes written. - Key: 26, size 148 bytes written. - Key: 27, size 148 bytes written. - Key: 28, size 148 bytes written. - Key: 29, size 148 bytes written. - Key: 30, size 148 bytes written. - Key: 31, size 148 bytes written. - Key: 32, size 148 bytes written. - Key: 33, size 148 bytes written. - Key: 34, size 148 bytes written. - Key: 35, size 148 bytes written. - Key: 36, size 148 bytes written. - Key: 37, size 148 bytes written. - Key: 38, size 148 bytes written. - Key: 39, size 148 bytes written. - Key: 40, size 148 bytes written. - Key: 41, size 148 bytes written. - Key: 42, size 148 bytes written. - Key: 43, size 148 bytes written. - Key: 44, size 148 bytes written. - Key: 45, size 148 bytes written. - Key: 46, size 148 bytes written. - Key: 47, size 148 bytes written. - Key: 48, size 148 bytes written. - Key: 49, size 148 bytes written. - Key: 50, size 148 bytes written. - Key: 51, size 148 bytes written. - Key: 52, size 148 bytes written. - Key: 53, size 148 bytes written. - Key: 54, size 148 bytes written. - Key: 55, size 148 bytes written. - Key: 56, size 148 bytes written. - Key: 57, size 148 bytes written. - Key: 58, size 148 bytes written. - Key: 59, size 148 bytes written. - Key: 60, size 148 bytes written. - Key: 61, size 148 bytes written. - Key: 62, size 148 bytes written. - Key: 63, size 148 bytes written. - Key: 64, size 148 bytes written. - Key: 65, size 148 bytes written. - Key: 66, size 148 bytes written. - Key: 67, size 148 bytes written. - Key: 68, size 148 bytes written. - Key: 69, size 148 bytes written. - Key: 70, size 148 bytes written. - Key: 71, size 148 bytes written. - Key: 72, size 148 bytes written. - Key: 73, size 148 bytes written. - Key: 74, size 148 bytes written. - Key: 75, size 148 bytes written. Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. Section: 321 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. Section: 322 - Key: 0, size 1 byte written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4902 bytes written. Completed in 3 min 11.609 s | |
04-14-2012, 14:12 | #14 (permalink) | |
Freak Poster Join Date: Mar 2012 Location: LAND of *****
Member: 1742117 Status: Offline Thanks Meter: 35 | Quote:
http://forum.gsmhosting.com/vbb/f550...ution-1031277/ | |
