06-15-2011, 22:24 | #2 (permalink) | |
No Life Poster Join Date: May 2006 Location: Algeria
Member: 274054 Status: Offline Thanks Meter: 400 | you are wrong Quote:
BR, | |
06-16-2011, 11:10 | #5 (permalink) |
Freak Poster Join Date: Feb 2011 Location: mumbai mira road Age: 51
Member: 1524461 Status: Offline Thanks Meter: 26 | remove old ufs sofware and driver instale new software 2.2.0.0 support suite first. update the box properly. then instale main setup 2.2.0.0. now the box will support mxkey also. try it. |
06-16-2011, 19:38 | #8 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 45
Member: 172424 Status: Offline Thanks Meter: 28 | hi mobileEx.lib 1 copy filrs folder C:\mobileEx\3.5 2 update nokia seul 3 copy files C:\mobileEx\3.5 |
06-17-2011, 05:41 | #9 (permalink) |
Junior Member Join Date: May 2007
Member: 503170 Status: Offline Thanks Meter: 3 | hi im also having Access violation at address 00000000 and cannot use my UFS as MX-key interface... Can someone give a work around on how to remediate this? Hopefully it is a step by step procedure. Please reply. Thanks |
06-17-2011, 10:55 | #10 (permalink) |
Member: 1524461 Status: Offline Thanks Meter: 26 | i have no problem this is created by our own mistake . fisrt install 3.5.1.1 mxkey setup . then update the box property then update minor updates also. blakberry nokia cdma now available. then un install ufs old setup & driver. install 2.2.00 support suite setup update box properly. now install main setup 2.2.00 if you have 2 ufs box then connect both box to usb before installing main setup box should be connected firt both box then install main set up. now you mxkey will support box hti box and ufs box. better then before. |
The Following User Says Thank You to ismail2005 For This Useful Post: |
06-17-2011, 12:18 | #11 (permalink) | |
Freak Poster Join Date: Dec 2007
Member: 642767 Status: Offline Thanks Meter: 27 | Quote:
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
