02-12-2010, 07:11 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | Warning: USB power is LOW ! when i go in nokia service tab then show this error- Warning: USB power is LOW ! i need solution. |
02-12-2010, 07:33 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 44
Member: 476739 Status: Offline Thanks Meter: 507 | you have use long wire usb change usb hub use other usb hub use direct usb socket not use this type hub [IMG]http://ic2.pbase.com/u19/james*****04/small/36300746.S_IMG_1270.jpg[/IMG] mickey-hub |
MX key Warning: USB power is LOW ! help me | ali.baydur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 03-20-2010 08:28 |
Combo + USB power + TX2 Line Cable Powered by USB and TX2 Enabled Compatible For NK 6 | IPMART | ipmart WebShop | 0 | 06-15-2009 07:40 |
WARNING: VPP pin is not connected, disabling VPP. | gsaalmeida | MT-BOX | 4 | 10-26-2007 07:04 |
