05-07-2011, 13:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Nepal
Member: 622060 Status: Offline Thanks Meter: 37 | anybody solve security test failed in N73? |
05-07-2011, 13:46 | #2 (permalink) |
Member: 622060 Status: Offline Thanks Meter: 37 | anybody solve security test failed in N73? hi i am requesting all of u to any body solve "Security Test Failed " in nokia -N73 ? i hav tried by recovering certificate & erase full flash, by getting rpl back up, but still same plz . i hav post logs here Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 3514E0F88931217BCD45EB6BA21947361BD7F30F ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 1700011815A40154E87104602DA3558C531A7420 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Original Imei: 35364001786209 Original Product code: 0529785 Bluetooth ID: 001979D8507A Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35364001786209-1 Product Code: 0529785 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353640017862091 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
05-07-2011, 14:01 | #3 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Where Dreams Become Realit Age: 28
Member: 645436 Status: Offline Thanks Meter: 1,501 | Quote:
1- scan 2-load hear modified pm fail 3-pmm auth click via online with MX KEY 4-write pm 5- click on action reset all setting 6-phone info 100000000% u r set is OK | |
05-07-2011, 14:07 | #5 (permalink) | |
1. super sd auth or pmm auth __than write good or modified pm ( must need pm 1 & 309) or, 2. sd repair ___ super sd auth or pmm auth ____ than write good or modified pm ( must need pm 1 & 309) when we not success by up system than what can we do for repair security test failed? Then 1. first backup rpl ( go > imei and security tab > imei rebuild > backup rpl) 2. erase old pm ( go > pm tab > erase ) 3. Reset npc data ( go> imei and security tab> reset NPC data)( must backup rpl before do this) 4. Erase pm again (go > pm tab > erase ) 5.Write rpl from backup ( go > imei and security tab > imei rebuild > restore imei) 6. go pm tab > super sd auth or pmm auth > than write good or modified pm ( must need pm 1 & 309) 7. erase pm again 8. Recover CERT ( go>imei and security tab> imei rebuild > recover cert) 9. give full factory reset your phone must come back from security test failed | |
05-07-2011, 14:18 | #7 (permalink) |
Freak Poster Join Date: Oct 2008
Member: 886190 Status: Offline Sonork: 12345678 Thanks Meter: 30 | Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) Processing MCU file: rm469_054.003_prd.core.fpsx [BB5,XSR 1.6] size: 101.30 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EB18A6C CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1C70020C857903440370AC77A7C8EC1E9DD514DE CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: EB18A6C Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35199604550620_CE RT.rpl" CMT PAPUBKEYS HASH: 85F252E351E225CAFC4DFBC8041EABD2823E3500 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 173.06 MB CMT MuxOneNAND area [00020000-0003FFFF] CMT MuxOneNAND area [00060000-004DFFFF] CMT MuxOneNAND area [008E0000-0B13FFFF] Formating partition ... Flash programming ... CMT PAPUBKEYS: 85F252E351E225CAFC4DFBC8041EABD2823E3500 (RAP Certificate 147 v.1) written. Programming completed in 23.750 s Processing PPM file: rm469_054.003_10.01_MENA_A_prd.rofs2.fpsx [BB5,XSR 1.6] size: 33.37 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 41.75 MB CMT MuxOneNAND area [07340000-09CFFFFF] Flash programming ... Programming completed in 7.843 s Processing CNT file: rm469_054.003_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 2.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 65.25 MB CMT MuxOneNAND area [0B140000-0F27FFFF] Flash programming ... Programming completed in 0.968 s Processing APE Variant file: RM469_APE_ONLY_ENO_09wk23v0.087.fpsx [BB5,XSR 1.6] size: 2.54 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4.00 MB CMT MuxOneNAND area [004E0000-008DFFFF] Flash programming ... Programming completed in 0.688 s Total time for flashing process(boot+erase+write) was 1 min 5.438 s Waiting for device boot up ... pls help |
05-07-2011, 14:18 | #8 (permalink) |
No Life Poster Join Date: May 2009 Location: On My KeyBoard
Member: 1038860 Status: Offline Sonork: 100.1593889 Thanks Meter: 173 | mate Go to Service Tab >phone tests >Various >Click on BB5 certificate Validation to see Hwc and ccc Data! then send log here for get batter assistance BR Smarty3399 |
05-08-2011, 01:21 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
ps. why still using older version? currently we have 3.4 rev 2.1 BR | |
05-08-2011, 14:27 | #11 (permalink) | |
Member: 622060 Status: Offline Thanks Meter: 37 | rstill same but now lost imei Quote:
Thanx for co-operation bro, but i hav perfomed according to ur tips but now showing imei empty, & still security test failed, i hav attached here logs RPL: "C:\mobileEx\3.4\data\backup\BB5_35364001786209_BA CK.rpl" Imei: 35364001786209 Updating PROD ...OK APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 3514E0F88931217BCD45EB6BA21947361BD7F30F ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 1700011815A40154E87104602DA3558C531A7420 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Updating CMT NPC ...OK Updating CMT VARIANT ...failed, Result: 0230000000517200 Updating PRODUCTCODE (0529785)... OK Updating PSN (SCL301318)... OK Updating HWID (6019)... OK Updating SUPERDONGLE_KEY ...OK Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0529785 Battery voltage: 4661 mV, current: 89 mA Language Pack: - not available. Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F | |
05-08-2011, 14:55 | #12 (permalink) | |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Quote:
No problem you have backup Restore it & Update Splock it | |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-23-1999 20:24 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
