12-03-2012, 16:28 | #1 (permalink) | |
No Life Poster Join Date: Dec 2005 Age: 40
Member: 213681 Status: Offline Thanks Meter: 108 | asha 201 after reset counter goes to contact service? i have a problem just unlock only. but phone cannt accept the code.(input code manually) so i dicide to counter reset or send nck code using box . (usb cable) it goes to contact service or data corrupted. what is the solution for this kind of problem? u have a pin out for asha 201? thanks. i flash the phone: Quote:
12-03-2012, 17:52 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Go to Service Tab > Quick Fix Tab > Tick XGold in this Image & Click Do Selected Job, Will solve it. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-03-2012, 18:21 | #3 (permalink) |
Freak Poster Join Date: Nov 2012 Location: HYD
Member: 1842056 Status: Offline Sonork: 100.1623514 Thanks Meter: 12 | zuber sir sure SIMLOCK_DATA corrupted problem solve it?? Go to Service Tab > Quick Fix Tab > Tick XGold in this Image & Click Do Selected Job, |
12-03-2012, 19:04 | #4 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
It will only solve Simlock Corrupted & Contact Service in XGold with Xgold213 CPU, If this occurs due to Reset Counter. BR, ZUBER | |
12-04-2012, 10:32 | #6 (permalink) | |
Member: 213681 Status: Offline Thanks Meter: 108 | Quote:
i have one more Q: I have problem with unlock this phone the counter is: Imei net: 3532760572xxc Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2340000100000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=CLOSED(MCCMNC), DATA=23430F [United Kingdom-T-Mobile UK ], 2=CLOSED(GID1), DATA=23430F [United Kingdom-T-Mobile UK ] But when i enter unlock code i have this message: Cannot undo restriction Any idea how fox this problem?? | |
12-04-2012, 11:06 | #8 (permalink) |
Member: 213681 Status: Offline Thanks Meter: 108 | Sending NCK 262064266625814 Trying mode: FBUS, NCK lock 7(ALL) ... OK: code accepted. Ok code accepted but i mast select BB5 platform but now i have this : SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed But phone works fine!! |
12-04-2012, 19:45 | #9 (permalink) | |
If your Phone working fine then OK, Then also want to remove this Error, then Flash it with Latest Firmware or same Product Code. BR, ZUBER | |
