Old 03-23-2010, 09:54   #1 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: xxx
Thanks Meter: 204
n95 8g rm-320 security fail need help :)
repair simlock ok
Product: V 06wk41v59 22-05-08 RM-320 (c) Nokia
Using cached productData[18900002777300521D47EFD033AEA6763892C8D1] ...
Calculating SIMLOCK using security server ...
Completed in 1.312 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-320_359542018200962_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 359542018200962
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
repair SD ok
Calculating SUPERDONGLE using security server ...
Completed in 4.156 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-320_359542018200962_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
but can not write pm 1 and 309
info
Phone Type: RM-320 (Nokia N95 8GB)
SW Version: V 06wk41v59 22-05-08 RM-320 (c) Nokia
Imei plain: 359542018200xx-x
Product Code: 0566134
Language Pack:
- not available.
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359542018200xxx
Counter: 0/3, 0/10
super sd auth and write fail
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized :)!
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 1 (4 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 5 (4 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 15 (4 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 27 (4 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 1.218 s
3
check various
Reading RAP NPC  (0x1B8 bytes)
Original Product Code: 0566134
Reading RAP VARIANT  (0x0 bytes)
VARIANT empty !
Reading RAP CCC  (0x160 bytes)
CCC seems to be valid
Reading RAP HWC  (0xD4 bytes)
HWC seems to be valid
what next i need to do?
thx u for help
Old 03-23-2010, 10:19   #2 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: xxx
Thanks Meter: 204
write rpl no NPC get error like this
NPC verified Ok.
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating APE HWC ...failed, Result: 0600000000317200
Certificate programmed successfully !
Old 03-23-2010, 10:28   #3 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
post here we will help you
http://forum.gsmhosting.com/vbb/f550...l-here-945700/
N95 8G Rm-320 no light lcd help? haigoshi Nokia Base Band 5 ( BB-5 ) 5 08-28-2010 01:06
N95 8G RM-320 [ Failed to extract the content ] MaikonPhone HWK 2 01-10-2010 19:51
n95-8g rm 320 chinese ppm needed owoeye Nokia Base Band 5 ( BB-5 ) 1 06-13-2009 08:36
N95 8G RM-320 downgrade with MT failed....help me... atlan Nokia Base Band 5 ( BB-5 ) 1 01-24-2009 08:03
Masters... i need pin out for N95 8g RM-320 -=whitezaNder=- Chinese Models & Cloned Phones 3 12-03-2008 04:08
Page generated in 0.29136 seconds with 9 queries
