09-16-2012, 08:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | bomb..nokia 110 rm-827 sucsesfully flash with mx-box Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010010C4 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.70 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Battery voltage: 5134 mV Waiting for USB device removal ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD__back.RPL" Processing file: rm827__03.04.mcusw Downloading item CODE:rm827__03.04.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.359 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.359 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.547 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 33.938 s Checksum verified (0x74A0) Processing file: rm827__03.04.ppm_m4 Downloading item CUSTackage_m4.ppm_ebl_psi.fls, num block: 1, size: 3.51 MB Erasing area 0x41BC0000-0x41F40996 ...OK Programming completed in 5.250 s Checksum verified (0xA432) Processing file: rm827__03.04.image_m4_059N407 Downloading item CUSTackage_m4_059N407.image.fls, num block: 1, size: 13.88 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 18.766 s Checksum verified (0xED62) Total time for flashing process(boot+erase+write) was 8 min 30.062 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 69FCCED Verifying communication to device OK. Phone type: RM-827 (Nokia 110) SW version: V 03.04 20-04-12 RM-827 (c) Nokia Imei plain: 35197005365280-5 Product code: 059N2R0 Language Pack: - not available. |
09-16-2012, 10:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Nice, You can also Post your Success Story here: http://forum.gsmhosting.com/vbb/f550...mxbox-1253878/ BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
