05-27-2011, 14:09 | #31 (permalink) |
Freak Poster Join Date: May 2006 Location: Nigeria,Lagos
Member: 275290 Status: Offline Thanks Meter: 50 | all your screen shots are correct, i also faces all this problem. N73 writing back the rpl error dct 4 flashing problems mxbox disconnect when flashing etc. So i believe manole will fix all the bug thanks in advance manole. |
06-01-2011, 07:47 | #32 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | MobileEx 3.5 rev 1.0 MXBOX Disconnection Problem While Flashing DCT4 Phone MobileEx 3.5 rev 1.0 MXBOX Disconnection Problem While Flashing DCT4 Phone |
The Following User Says Thank You to ..::AppleLinks::.. For This Useful Post: |
06-01-2011, 09:46 | #34 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
@applelinks: - dct4 bugs: negative. check your system and cables. Code: MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] - C0696666 Using device: HTI BOX, FW ver: 00.08 Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.17317(01-06-2011), Library ver: 1.0.0.10695(31-05-2011) Processing MCU file: rh122_005.010 [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...Area [01000000-0100FFFF] erased in 0.355 s Area [01010000-0179FFFF] erased in 41.306 s Area [017A0000-017EFFFF] erased in 1.747 s Area [01F00000-01FDFFFF] erased in 0.107 s Flash programming ... Programming completed in 17.501 s File Processed in 1 min 22.546 s Processing CNT file: rh1220_nai05.01md [DCT4,DCT4 ALGORITHM] size: 208.39 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...Area [01750000-0178FFFF] erased in 1.388 s Flash programming ... Programming completed in 1.555 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.750 s File Processed in 47.658 s Processing PPM file: rh122_005.01md [DCT4,DCT4 ALGORITHM] size: 3.04 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...Area [01250000-0125FFFF] erased in 0.342 s Area [01260000-0174FFFF] erased in 26.955 s Flash programming ... Programming completed in 22.423 s File Processed in 1 min 11.291 s Total time for flashing process(boot+erase+write) was 3 min 21.501 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RH-122 SW Version: V 05.01 23-09-09 RH-122 (c) Nokia Imei plain: 35605503579849-9 Product Code: 0572834 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MD Language Pack: English,Filipino,Vietnamase Imei net: 35605503579849 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN please keep reporting. very appreciate it BR | |
06-01-2011, 12:14 | #35 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | MobileEx 3.5 rev 1.0 MXBOX BB5 Backup RPL Writing Error |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
