10-04-2011, 05:14 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | C1-00 rm689 flashed ok but not powers on? ## (ANSWERED) Any suggestion plz.??????????/ MXKEY Serial: [FT xxxxxxxxxxxx- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: UHCI:HUB:USB 1.10 (Full-speed) Driver: UFS2XX, ver: 3.1.5.0 , NTMP ver: 2.2.4.1 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921.60 Kbps Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing file: rm689_002.600 Downloading item CODE:hw_s01_rm689_r02.600.fls, num block: 3, size: 4.08 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 45.313 s Erasing area 0x00C60000-0x00E6477E ...OK Programming completed in 44.343 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.188 s Checksum verified (0xAF9A) Processing file: rm689_002.60ia Downloading item CUST:hw_s01_rm689_002.60ia.fls, num block: 1, size: 2.02 MB Erasing area 0x00210000-0x00414A7E ...OK Programming completed in 44.047 s Checksum verified (0x90E0) Processing file: rm6890_nai02.60ia Downloading item CUST:hw_s01_rm6890_nai02.60ia.fls, num block: 1, size: 327.45 KB Erasing area 0x00EB0000-0x00F010BE ...OK Programming completed in 7.015 s Checksum verified (0x24CB) Total time for flashing process(boot+erase+write) was 3 min 15.625 |
10-04-2011, 05:59 | #3 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Mates although I have solved many times dead after flash with new versions by flashing with 2.60 but in your case it is dead with 2.60 so flash with version 3.00 if still same flash again with 2.60 or another lower version because Infenions can be downgraded. WBR |
10-04-2011, 06:48 | #6 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: dimapur, nagaland
Member: 1416083 Status: Offline Sonork: 1640399 Thanks Meter: 16 | Quote:
1.remove lcd 2. check the track [second and third print from right might be missing, i found in many cases] | |
The Following User Says Thank You to premsharma For This Useful Post: |
10-04-2011, 11:53 | #10 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Mate as its LCD is damaged how it can show Test MOde so Take info and you will see in logs that its LCD is damaged I usyally check with HWK or ATF it shows LCD test Faild in ATF and in HWK UNknow LCD ID when phone LCD is damaged. WBR |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
