11-23-2011, 14:54 | #1 (permalink) |
Registered User Join Date: Nov 2010 Location: talamba punjab pakistan Age: 34
Member: 1437921 Status: Offline Sonork: 100.1668345 Thanks Meter: 13 | c5 flashing ok but only Vibration pls help me (ANSWERED) how to manual erase adress befor flash i do the bb5 rap3nand erase user area ???????? MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0853A2A Using device: HTI, FW ver: 00.24, SN: 00000BD5 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 216000046D9F5740C34300EEEEC55031BAB11EED ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 42.282 s Processing PPM file: rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx [BB5,XSR 1.6] size: 36.45 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 46.641 s Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.01 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 0.453 s Processing CNT file: RM645_ENO_10wk48v0.001.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 6.907 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 4.938 s Total time for flashing process(boot+erase+write) was 6 min 52.046 s |
11-24-2011, 06:50 | #3 (permalink) |
Member: 1437921 Status: Offline Sonork: 100.1668345 Thanks Meter: 13 | i do this option befor flash how to solve ??? how to manual erase adress befor flash i do the bb5 rap3nand erase user area |
11-24-2011, 07:42 | #4 (permalink) |
Member: 1437921 Status: Offline Sonork: 100.1668345 Thanks Meter: 13 | after do this & flash same only vibrate any solution ???? MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C0853A2A Using device: HTI, FW ver: 00.24, SN: 00000BD5 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 216000046D9F5740C34300EEEEC55031BAB11EED ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 45.766 s Processing PPM file: rm645_071.005_10.01_MEA_A_prd.rofs2.fpsx [BB5,XSR 1.6] size: 35.84 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 44.968 s Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.01 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 0.438 s Processing CNT file: RM645_ENO_10wk48v0.001.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 6.875 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 4.625 s Total time for flashing process(boot+erase+write) was 6 min 55.062 s |
11-24-2011, 08:03 | #5 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | flash only ppm, use this file name: RM645_ENO_10wk48v0.001.fpsx use search button for it to download. my inet is quite stuck now, can't upload it bro... good luck bro br |
11-24-2011, 14:41 | #6 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
1. Flash with this file: C5-00_rm645_CareDP_1.0_BASIC_UPLOADED_BY_SUPER_MOBILE EX.zip 2. You must flash with latest firmware version after. if still the same problem, bad flash chip. reheat, reball. BR @specta: ENO cnt, is different with ENO 'base engine' | |
The Following User Says Thank You to gbluez For This Useful Post: |
11-25-2011, 12:40 | #7 (permalink) |
Member: 1149800 Status: Offline Thanks Meter: 211 | ENO cnt, is different with ENO 'base engine' meaning sir? i'm newbie in software business... please guide me... im downloading the file u gave above too... for preparation. thanks in advance br |
11-25-2011, 13:37 | #8 (permalink) |
Member: 1149800 Status: Offline Thanks Meter: 211 | @gbluez sir, i installed the file, but i can't find mcu file: rm645_Eve_Substrate_test_10w14_PRD.cmt. there is only rm645_ENO_v_0.NCP17_APEONLY.fpsx. do i have to put 2 files or just cnt only? please give me a brief explanation. thanks in advance sir br |
