Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 02-04-2010, 18:43   #1 (permalink)
ntothel's Avatar
Member: 266180
Thanks Meter: 25
Can i repair 3110c with imei 12345610654321 with MX KEY please help
Please help me i have 3110c with imei 12345610654321 here is the log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11446, Date: 25-11-2009
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 17E0010271587E563CA3BB8233FD56636354D0C9
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Original Imei: Empty
Original Product code: Empty
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 12345610654321-?
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2008-01-18T09:29:04Z
SW Version: 06.01
Variant Version: 009
ProductProfile: RM237_0514950_06.01_009.spr
Simlock: 0514950_simlock.bin
Imei plain is invalid !!!
Imei net: 12345610654321?
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 2 Users Say Thank You to ntothel For This Useful Post:
Old 02-04-2010, 18:53   #2 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 06.01
Counter: 0/3, 0/10
not yet without rpl wait for more update
The Following 2 Users Say Thank You to ..::Rizwan::.. For This Useful Post:
Old 02-04-2010, 19:16   #3 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
make backup full pm and cert after that try to lowest ver flashing
its not help wait untill rpl solution appear
sphameed
Old 02-04-2010, 19:33   #4 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
do you have cert bakup?
if yes restore it
if no,not possible
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 10-10-2010, 11:26   #5 (permalink)
Member: 492622
3110c imei empty,
product code empty,
nps data missing.
i think i have rpl backup for this phone, but hw can i find in my backup folder?, bcoz in this folder many more rpl file . i have 3 backup folder 1-jaf, 2 ufs hwk, 3 mxkey.
not remember what device i use for first time flashing. inside battery imei no missing. not remember what original imei.
any one have any trick to find imei no. ?
pls pls pls help me.
Old 10-10-2010, 13:13   #6 (permalink)
Baba Khanikar's Avatar
Member: 1126485
Sonork: 100.1605067
Thanks Meter: 32
If u Have d back Sticker just go 2 d folders and type d IMEI no on d serch button...
Old 10-10-2010, 13:34   #7 (permalink)
Member: 631452
Thanks Meter: 6
connect the set via mx kea and click on bus check where u can c its original imei then u can find related backup from ur data base ... good luck
Old 10-10-2010, 14:41   #8 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
not yet without rpl...............
Old 10-10-2010, 14:43   #9 (permalink)
.:::Ayaz:::.'s Avatar
Member: 1403951
Sonork: 100.1586892
Thanks Meter: 213
with out rpl not solve ur problem mate
Ayaz
Old 10-10-2010, 18:17   #10 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK_TEST passed
SW Version: 06.01
Counter: 0/3, 0/10
You can only if you have the old backup.
If you not have, you will need RPL.
To buy BB5 RPL please contact with Fast Unlocking
BR,
Manole
The Following 5 Users Say Thank You to MANOLE For This Useful Post:
mx key team help me how to get log txt of mx key sanjayvikas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 01-22-2010 12:48
please help imei function in mx key bijugreat MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-07-2010 01:26
how to unlock 2610b .07.04a on mx-key please help ner21 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 12-30-2009 12:47
3110c show imei 12345610654321 skd_123 Nokia Base Band 5 ( BB-5 ) 7 12-29-2009 10:11
Page generated in 0.23319 seconds with 9 queries
