11-16-2011, 11:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Can USB be used for quick fix? (ANSWERED) FBUS can not connect. Here is buscheck log using USB: Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12923(10-10-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5846229 CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 13C00106AF83005227C0F338848E507CDAE47324 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 00000000000000 Original Product code: SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL Reading CMT NPC (0xFF bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0xFF bytes). Reading CMT HWC (0xFF bytes). Reading CMT R&D (0xFF bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5846229 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdc\Nokia E63 USB Phonet, PORT_ID: 20F6C18B Verifying communication to device OK. Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia Imei plain: 35693903732517-1 Product code: 0590132 Battery voltage: 4044 mV, current: 128 mA ApeVariant: 510.21.010510.21.010_v26 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356939037325171 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN I need to erase user area bb5 rap3nand using usb, but error... here is the log: Battery voltage: 4039 mV Phone type: RM-437 (Nokia E63) Product code: 0590132 SW version: 510.21.010 LanguagePkg version: 510.21.010510.21.010_v26 Version from phone: 510.21.010 Version from file: 501.21.001 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5846229 Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5846229 CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 13C00106AF83005227C0F338848E507CDAE47324 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C CMT ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD reading boot config 1 failed! now here come the questions: 1. does mxkey support usb for this operation?? 2. how come eBB5ProtocolType is OLD while doing quickfix, since while doing busckeck it is NEW?? thanks in advance br |
11-16-2011, 12:36 | #3 (permalink) |
Freak Poster Join Date: Oct 2011 Location: INDIA - GUJARAT
Member: 1680941 Status: Offline Sonork: +91-7567507692 Thanks Meter: 21 | Try to fbus cable and post result here, but check hardware first change lcd and try again i think this is a lcd problem, any way post result here. |
07-30-2012, 15:36 | #6 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | i try fbus without success but phone is in local mode on the lcd but can't switch on after. Quote:
07-30-2012, 17:32 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. U can see 4 options for Protocols in Image below, only Tick Auto Select & Untick last 3 options. BR, ZUBER |
07-31-2012, 07:55 | #8 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | usb as fbus don't work sir. when click "check" on fbus with hwk it can't boot but by usb i can flash without problem and phone display local mode on LCD but at the end not switch on. i write blank pmm but not. |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
