02-21-2010, 05:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: sl3 & simlock data Age: 35
Member: 1211533 Status: Offline Sonork: 100.1579942 Thanks Meter: 20 | cant solved 5130 security test failed SW Version: V 07.91 29-10-09 RM-495 (c) Nokia Imei plain: 35932902820594-6 Product Code: 0579030 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! "RM-495" folder created. Imei net: 359329028205946 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF also Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.91 29-10-09 RM-495 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 - Key: 0, size 12 bytes written. - Key: 1, size 70 bytes written. - Key: 2, size 70 bytes written. - Key: 3, size 70 bytes written. - Key: 4, size 70 bytes written. - Key: 5, size 276 bytes written. - Key: 6, size 276 bytes written. - Key: 7, size 276 bytes written. - Key: 8, size 276 bytes written. - Key: 9, size 384 bytes written. - Key: 10, size 384 bytes written. - Key: 11, size 384 bytes written. - Key: 12, size 384 bytes written. - Key: 13, size 384 bytes written. - Key: 14, size 384 bytes written. - Key: 15, size 384 bytes written. - Key: 16, size 384 bytes written. - Key: 17, size 32 bytes written. - Key: 19, size 16 bytes written. - Key: 20, size 32 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. - Key: 22, size 12 bytes written. Completed in 1.625 s still same problem pls help how can i solved ? |
The Following User Says Thank You to u & me For This Useful Post: |
02-21-2010, 05:52 | #2 (permalink) |
Junior Member Join Date: Sep 2009 Location: mx key is the best nokia tool
Member: 1112394 Status: Offline Sonork: 100.9645008 Thanks Meter: 15 | Mate 5130 is not supported at the moment so waiting 4 it Regards |
The Following User Says Thank You to zahid009 For This Useful Post: |
02-21-2010, 06:23 | #3 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | 5130 is sl3 phone.sl3 not supported at the moment u can wait for sl3 unlocking. following model not supported RAPUYAMA v1.11 PR_RTSA_BGA401/CSP - PA_SL3 Security 5630d (RM-431) 6720 Navigator (RM-491) 6700 Classic (RM-470) 6720 Classic(RM-424) 6730 Classic (RM-547) 6730 Classic (RM-566) 7020a (RM-497) E52 (RM-469) E55 (RM-482) E72 (RM-529) E72 (RM-530) RAPIDOYAWE 1.13E - PA_SL3 Security 5730s (RM-465) 5530 (RM-504) 5800d (RM-356) - v10.4.016 with HASH: 479C6DDE3942E12C429C1D6ADED80371 N97 (RM-505/506/507/555) RAPS_V3.03/3.02 - PA_SL3 Security 2700 Classic (RM-561) 2730 Classic (RM-578) 2730c-1b (RM-579) 3600 Slide (RM-352) v56.26 - v57.23 3720 Classic (RM-518) 5130 XpressMusic (RM-495) 5310 XpressMusic (RM-303) v58.58 - v59.42 6202 Classic 6300 (RM-217) v57.20 6303 Classic (RM-443) 6500 Slide (RM-240) v59.60 6500 Classic (RM-265) v59.45 7610 Slide (RM-354) v57.23 RAP3GS2 v4.1/4.11_C021 - PA_SL3 Security 3710a-1 (RM-509) 3710a-1b (RM-510) 3711a-1 (RM-511) RAPS2 v4.1/4.11 - PA_SL3 Security X3 (RM-540) X6 (RM-559)br, |
The Following 2 Users Say Thank You to Ramzan khan For This Useful Post: |
02-21-2010, 06:32 | #5 (permalink) |
Member: 1211533 Status: Offline Sonork: 100.1579942 Thanks Meter: 20 | @zahid009 and @ramzan khan if u know so u can answer .if dont know u can leave .dont need wrong answer anyway i solved my problem |
02-21-2010, 07:42 | #11 (permalink) |
Freak Poster Join Date: May 2007 Location: UAE
Member: 513874 Status: Offline Thanks Meter: 178 | 5130 SD support only simlock not support yet Security test failed possible 100000000% contact me on yahoo...... |
The Following User Says Thank You to greeney For This Useful Post: |
02-21-2010, 10:08 | #12 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | this case need SX-4 and write PM without[308] area SIMLOCK repair NOT SUPPORTED YET SUPERDONGLE repair already supported br, |
The Following User Says Thank You to Andra For This Useful Post: |
nokia n76 sucussfully phonestartup failure solved .security test fail solved | manish_jain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-14-2011 06:55 |
mxkey can't solve security-test failed. | mobilezone1997 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 11-08-2010 14:53 |
5130-c2 security test failed! | Arjun mishra | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-03-2010 13:14 |
7210c CONTACT SAERVICE security test failed [ Solved ] | jermaineyork | Cyclonebox | 4 | 02-04-2010 06:35 |
security test Fail nokia 5800 [SOLVED] | langin | Cyclonebox | 10 | 01-10-2010 22:34 |
