Old 05-13-2010, 14:48   #1 (permalink)
Member: 460989
Thanks Meter: 11
problem flashing 2680s
need help...problem flashing 2680
here is the log
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
Performing Flash Authentication ...OK
UEM ID: 00916576:DA3BDA66
ASIC type: 11
UEM Imei: 35319803309050
Flash Imei: 35319803309050
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35319803309050_BACK.rpl"
Processing file: rm392__04.56.mcusw as MCU
 [DCT4,DCT4 ALGORITHM]  size: 11.75 MB
 Supported Ids: 3160, 3161, 3162, 3164, 3166
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH
UEM ID: 00916576:3B8ADA60
Area [01000000-0101FFFF] erased in 1.171 s
Area [01020000-01CFFFFF] erasing ...
Error while erasing 0x01200000-0x0121FFFF, Result: 01000000
flashing terminated !
Flashing terminated with error(s) in 1 min 25.016 s
RX Buffer: 0100000000B172
Old 05-13-2010, 14:55   #2 (permalink)
Member: 460989
Thanks Meter: 11
also when flashing 6070 it shows same error....is this a bug??
Old 05-13-2010, 15:10   #3 (permalink)
Member: 629228
Thanks Meter: 17
check flash cable connection, mine after the flash can even unlock via server
Imei net: 356390028*****
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 5555555555555555
PROFILE_BITS: 5555555555035555
SIMLOCK_DATA corrupted!
Calculating SIMLOCK RPL using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
[CR1]DCT4PLUS remaining credit: 46
Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-392_356390028*****_SIM.RPL"
Updating SIMLOCK ...OK
Reading Simlock info ...
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
The Following User Says Thank You to naurah For This Useful Post:
Old 05-13-2010, 15:11   #4 (permalink)
Member: 629228
Thanks Meter: 17
i use universal cable
Old 05-13-2010, 15:13   #5 (permalink)
Member: 460989
Thanks Meter: 11
i need pin out...can u share please
Old 05-13-2010, 15:28   #6 (permalink)
Member: 629228
Thanks Meter: 17
sorry, i upload file failed
Old 05-13-2010, 15:31   #7 (permalink)
Member: 460989
Thanks Meter: 11
how many pins did u use??????????//
Old 05-13-2010, 19:42   #8 (permalink)
Member: 629228
Thanks Meter: 17
i used 5 pin,
con batt
l l l
sory for the pic
Old 05-13-2010, 20:48   #9 (permalink)
Member: 1295798
Sonork: brista786
Thanks Meter: 97
bro use mxkey ufc cable set i hope ur problem will be solved
The Following User Says Thank You to True Man For This Useful Post:
Old 05-17-2010, 17:25   #10 (permalink)
Member: 1296356
Sonork: n/a
Thanks Meter: 40
here is the log
ASIC type: 11
Same to me .Please write the complete guide for flash 2680s by MXKEY or JAF.
Need quick response .
Thanks advanced
Old 05-17-2010, 17:29   #11 (permalink)
sijibae's Avatar
Member: 1169189
Sonork: 100.1591528
Thanks Meter: 94
use 5.1k, if still not success - force using 7.5k
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.25092 seconds with 9 queries
