08-03-2010, 13:00 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: PAKISTAN
Member: 290794 Status: Offline Thanks Meter: 31 | dear manole plz help me here is log what is wrong plz help me ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008C93F1A3BDA66 ASIC type: 11 UEM Imei: 35318503116053 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\3531850311605 3.RP L" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008C93F1A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! |
08-03-2010, 13:56 | #4 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Quote:
then try to repair imei | |
The Following User Says Thank You to Ramzan For This Useful Post: |
08-03-2010, 14:07 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | I'd like to help you, but i can not since you do not have eyes to read : warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed BR, Manole |
The Following User Says Thank You to MANOLE For This Useful Post: |
08-03-2010, 15:55 | #7 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: BD/HAIL KSA
Member: 1001269 Status: Offline Thanks Meter: 226 | Quote:
Thank you for Help him Dear MANOLE Sir you know better then me USB prot output voltage 5.0 where can give 5.2 volt ? so you and Alim sir made a now BOX for MX-KEY with extra power supply | |
08-03-2010, 17:54 | #9 (permalink) | |
Crazy Poster Join Date: Mar 2010
Member: 1273455 Status: Offline Thanks Meter: 5 | Quote:
08-03-2010, 18:22 | #10 (permalink) |
Crazy Poster Join Date: Mar 2006
Member: 242267 Status: Offline Thanks Meter: 5 | ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001641F2A3BDA66 ASIC type: 11 UEM Imei: 35420503244569 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "D:\mobileEx\3.4\data\backup\RPL\35420503244569.RP L" ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001641F2A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RM-394 (Nokia 1680c) SW Version: V 06.82 26-09-08 RM-394 (c) Nokia Imei plain: 35420503244569-1 Product Code: 0569109 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: S Language Pack: - not available. Imei net: 35420503244569 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
08-03-2010, 23:52 | #12 (permalink) |
Freak Poster Join Date: May 2007 Location: france
Member: 511668 Status: Offline Sonork: 100.1604959 Thanks Meter: 8 | ser i have a n95 8gb unlock with mxkey after contact service after full try sd reper simlock reper simlock restore flash & erese flash but phone still no power i have rpl full backap with mxkey plz help how to my phone full flash fbus & usb flash err this time my phone only front key light power on still work plz help |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
