Old 08-03-2009, 11:15   #1 (permalink)
Member: 996684
Thanks Meter: 46
N70 Flashing Error
i m having follwing error while flashing n70.
Processing file: RM84_50737301.C0
APE Data :
SYSTEM ASIC ID: 17100701 [OMAP1610 ver: 1.1]
ASIC MODE ID: 00
PUBLIC ID: C4F610F0EA7EAD751B6873CCE1322D8E8A650532
ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2]
EM1 ID: 00000232
EM2 ID: 00000353
PUBLIC ID: 0880000239715A5133DEDE0FE46102BA452B4E0A
ASIC MODE ID: 00
ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
ROM ID: F28A211FCEA7B19D
rap3gv2_2nd.fg: [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS ID: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
helen3_2nd.fg: [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
RX2 enabled.
Flashing terminated with error(s) in 12.688 s
RX Buffer: 000000009372
PLZ help
Old 08-11-2009, 14:49   #2 (permalink)
Member: 996684
Thanks Meter: 46
plz help mxkey team. no reply in 10 days
Old 08-11-2009, 21:09   #3 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Did you enabled the Rx2 & Tx2 then flash the phone.If not,so try it then post result here.
The Following 2 Users Say Thank You to Vijendra Saini For This Useful Post:
Old 08-12-2009, 15:33   #4 (permalink)
Member: 996684
Thanks Meter: 46
yes i did but same problem
Old 08-14-2009, 05:24   #5 (permalink)
Member: 996684
Thanks Meter: 46
mxkey team plz tell me wht is the problem
Old 08-14-2009, 05:41   #6 (permalink)
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Sorry for the late.
I want to know what is the back groud of the handset.
The Following User Says Thank You to Vijendra Saini For This Useful Post:
Old 08-14-2009, 05:48   #7 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Hi,
would be better if before flashing you doing a "BUS check".
and will be best if you post 'mobileEx.log' instead of window log.
BR.
The Following User Says Thank You to Alim Hape For This Useful Post:
Old 08-14-2009, 05:49   #8 (permalink)
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
One more thing can you please show here a bus check information?
Old 08-17-2009, 06:03   #9 (permalink)
Member: 996684
Thanks Meter: 46
Sorry for the late.
handset was on white light screen
Old 08-17-2009, 06:05   #10 (permalink)
Member: 996684
Thanks Meter: 46
Originally Posted by i-mobile View Post
Hi,
BR.
i cant find mobileEX.log file in mobileex folder
Old 08-17-2009, 14:51   #11 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
your handset has an hardware problem first clean and re flash
Nokia N70 Flashing Error fusion007 Universalbox 36 11-01-2010 14:22
Page generated in 0.15906 seconds with 9 queries
