03-16-2010, 10:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Saudi Arabia
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | E71 rm (407) after 5 mint mobiel tern off......? SW Version: V ICPR71_09w22.9 16-10-09 RM-407 (c) Nokia Imei plain: 35292602057211-1 Product Code: 0572955 ApeCoreSw: 400.21.013 ApeVariant: 400.21.013, ApeTest: RM346ENO74110842.a36 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352926020572111 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF how can solve this pro...........also need good pm for this rm 407 pls help me...... |
03-16-2010, 10:54 | #3 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | Quote:
The Following User Says Thank You to Misbahullah For This Useful Post: |
03-19-2010, 20:41 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | u can slove your problem 1_mxkey>serves>imei&securty>imei rebuild>repair sd 2_go to pm >click sd auth writ pm 1 and 309 and wait 2 mnt 3_full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
03-19-2010, 21:17 | #8 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 72951 Status: Offline Thanks Meter: 63 | I did everythig you said but when I went to write 1 and 309 I got this; Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 35 (16 bytes) Warning: failed to write 1 - 37 (4 bytes) Warning: failed to write 1 - 39 (36 bytes) Warning: failed to write 1 - 40 (16 bytes) Warning: failed to write 1 - 41 (182 bytes) Warning: failed to write 1 - 42 (4 bytes) Warning: failed to write 1 - 43 (36 bytes) Warning: failed to write 1 - 45 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 10.244 s Phone says; Phone start-up failed. Contact the retailer. |
6300 powered off after 5 mint | ASIF JAAn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-17-2010 10:49 |
E71 rm (407) after 5 mint mobiel tern off......? | alavukt | Cyclonebox | 3 | 03-16-2010 10:30 |
any one know how to unlock nokia e71 rm-407 connectivity ok but not | 33872 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-16-2010 17:20 |
E71 rm-407 converted sucessfully | lakshi | Nokia Base Band 5 ( BB-5 ) | 8 | 04-23-2009 05:50 |
Help Nokia 5200 truns off after 5 mints | brain00000 | Nokia Hardware & Hardware Repair | 5 | 11-21-2007 12:52 |
