03-15-2011, 21:58 | #1 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1494030 Status: Offline Thanks Meter: 0 | Error The handle is invalid (code: 6)MXKEY ## (ANSWERED) the same problem when connect with blackberry.thanks for advice. Using device: AdvanceBox Turbo Flasher Box status: NOT ACTIVATED Error opening ! Last error: The handle is invalid (code: 6) AdvanceBox Turbo Flasher disconnected. |
03-16-2011, 05:40 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, can atf soft work with your box correctly? try to repeat atf driver installation. it is suggested to always use current version. there are main update and some partial update of mobileEx version. Download: 3.4 REV 1.9 http://www.mxkey.biz/mobileEx_setup_...10301).exe.zip Module Update: click. |
03-17-2011, 19:01 | #3 (permalink) |
Member: 1494030 Status: Offline Thanks Meter: 0 | Thank you brother for you advice , I changed the version and installed ,but the problem is not fixed it as below: Using device: AdvanceBox Turbo Flasher Box status: NOT ACTIVATED Error opening ! Last error: The handle is invalid (code: 6) AdvanceBox Turbo Flasher disconnected. |
03-17-2011, 20:47 | #4 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, you didn't answer my question. can atf soft work with your box correctly? proper usage: also please activate your box first BR |
The Following User Says Thank You to gbluez For This Useful Post: |
03-17-2011, 23:52 | #5 (permalink) | |
Member: 1494030 Status: Offline Thanks Meter: 0 | Quote:
Yes sir the ATF work with out any problem,but when i use the Mxkey by ATF that message above is appear,the same problem with Blackberry. thank you. | |
03-20-2011, 01:46 | #9 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | to Lieren and Ploto, hello friends, i merged your thread. please try to perform driver re install procedure. run atf driver uninstaller, unplug box, run C:\Program Files\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers plug box, use driver from C:\Program Files\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS. anyway, what is your windows version? (start menu > run > type "winver") BR |
03-26-2011, 14:51 | #11 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: iCloud ID Removed Service
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | Quote:
04-04-2011, 10:58 | #13 (permalink) | |
04-08-2011, 19:21 | #14 (permalink) |
No Life Poster Join Date: May 2006 Location: Sri Lanka
Member: 282757 Status: Offline Sonork: 100.1606418 Thanks Meter: 34 | [IMG]file:///C:/Documents%20and%20Settings/Hayam.AL-HAYAM/Desktop/blackberry.JPG[/IMG] pls Help me Last edited by Fazil; 04-08-2011 at 19:28. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
