Old 10-24-2012, 08:54   #1 (permalink)
Member: 747386
Thanks Meter: 30
5130 contect service
hi br
nokia 5130 contect service here is logs
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D
Using device: HTI, FW ver: 00.50, SN: 010016CF
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0F40020D9FA77D566A7DC75502DF93417C9D6AA8
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35417903621790
Original Product code: 0572174
Bluetooth ID: 002548246EB0
SIMLOCK PA identifier:
[0] PA_SL3
Phone type: RM-495 (Nokia 5130c-2)
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35417903621790-3
Battery voltage: 4867 mV, current: 63 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Old 10-24-2012, 09:05   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
You know it's SL3 Phone.
If Backup RPL All Section their in PC,
Write RPL Manually will do the Job,
Or else have to Buy Factory RPL.
BR,
ZUBER
Old 10-24-2012, 09:19   #3 (permalink)
Member: 747386
Thanks Meter: 30
Originally Posted by .::ZUBER::. View Post
Hi,
BR,
ZUBER
HRER IS BACKUP RPL LOGS
Reading RPL backup ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Flash Imei: 35417903621790
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35417903621790_BA CK.rpl"
Old 10-24-2012, 09:19   #4 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 158
Hello Zuber!
I dont think the guy problem is IMEI issue. Backup rpl can only restore phone IMEI
and the phone IMEI seems to be OK.
SO, Having a full PM backup or PM 120 will solved his problem.
~Or Full flash Backup and restore Simlock {function in BEST or A.T.F}
SIMLOCK TEST failed
~ReGaRds
Old 10-24-2012, 09:58   #5 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Originally Posted by chubbie View Post
Hello Zuber!
SIMLOCK TEST failed
~ReGaRds
Hi,
Do you read my post carefully before,
If don't know then keep Quit,
Do you Know RPL Contains Simlock Data?
Select All Section on IMEI & Security Tab & Click Backup RPL,
Will saved NPC, Simlock Data, All Certificates & PM.
if don't know, then watch my Logs or can check with your own.
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DA85
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00011D3F
Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14213(16-10-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000005C5E344455819439CF0B466E09CD16
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 27D1DA66
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
Original Imei: 35623604917107
Original Product code: 059F8G7
Bluetooth ID: D45D4274C06F
[0] PA_SL3
Waiting for device boot up ...
Device connected: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 2054E2AA
Verifying communication to device OK.
Phone type: RM-618 (Nokia X2-00)
SW version: V 04.90 28-09-10 RM-618 (c) Nokia
Imei plain: 35623604917107-7
Battery voltage: 3839 mV, current: 1 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NI00BC0000040103B904, ver: 009.008
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
Imei net: 356236049171077
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
After Select All Section & Click Backup RPL
Battery voltage: 3829 mV
SW version: V 04.90 - 28-09-10 - RM-618 - (c) Nokia
LanguagePkg version: 0 - 28-09-10 - RM-618 - (c) Nokia - MH
Flash Imei: 35623604917107
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA is empty.
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA is empty.
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35623604917107_BA CK.rpl"
I think you got it now.
Better not to recommend Other Tools(Crap) here,
The HTI Box Functions cannot compare with others.
BR,
ZUBER
Old 10-24-2012, 10:22   #6 (permalink)
Member: 747386
Thanks Meter: 30
Hi,
BR,
ZUBER
br Zuber
i have backup rpl and pm but log is change here is logs
Product code: 0571584
Battery voltage: 4879 mV, current: 55 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.012
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SECURITY_TEST failed!
Old 10-24-2012, 10:30   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi Friend,
Simlock Data Corrupted, Empty in your Backup RPL, may not Backup All Section.
If you Readed & Backed up Sim RPL before will work in this case,
At last Buy Factory RPL.
BR,
ZUBER
Old 10-25-2012, 08:11   #8 (permalink)
chubbie's Avatar
Member: 281801
Sonork: 100.1608672
Thanks Meter: 158
Ok, How will one restore the Backup RPL then
~Choose WRITE RPL as someone is writing a bought factory RPL..
Old 10-25-2012, 08:20   #9 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Yes Friend,
You're right,
Writing same as you mention will write all fields including IMEI, Simlocks, Certificates etc.
Restore IMEI will only write NPC, means only IMEI & no other Data.
BR,
ZUBER
Page generated in 0.20388 seconds with 8 queries
