04-08-2012, 11:16 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | yes, click flash & bring phone to USB mode by turn off your N9 and connect it to the PC via USB hold onoff button until the mxkey detects the boot loader and once it detected then start flashing. once the flashing is completed the first power on will take a long time so be patient, i hope you understand & have a good day. |
The Following 2 Users Say Thank You to .::ZUBER::. For This Useful Post: |
04-19-2012, 18:45 | #5 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 759190 Status: Offline Thanks Meter: 4 | doesnt work for me... mine has a security code that i want to remove MXKEY [FT SCR2000 0], SN: C084B29B Using device: USB ROM Connection status: No device connected Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Done. Sleeping for 15 seconds while device boot up ... |
04-19-2012, 19:34 | #6 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
http://forum.gsmhosting.com/vbb/f550...hread-1451811/ Follow exactly mobileex direction given on logs Code: When USB cable gets connected it powers the phone and set's it to flashing mode | |
04-19-2012, 19:46 | #8 (permalink) |
Member: 759190 Status: Offline Thanks Meter: 4 | something new appears: MXKEY [FT SCR2000 0], SN: C084B29B Using device: USB ROM Connection status: No device connected Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) Remove USB cable from device. Turn off the phone Press and hold down key 'u' Connect USB cable between the phone and host PC while still holding down key 'u' When USB cable gets connected it powers the phone and set's it to flashing mode Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for Maemo USB device ... Done. Sleeping for 15 seconds while device boot up ... |
The Following User Says Thank You to achidrift For This Useful Post: |
04-27-2013, 13:11 | #9 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 345808 Status: Offline Thanks Meter: 21 | MXKEY [USB CCID Smart Card Reader 0], SN: C0803135 Using device: USB ROM Connection status: No device connected Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Waiting for USB interface ... Found device RM-696, hardware revision 1603 NOLO version 2.3.6 Version of 'sw-release': DFL61_HARMATTAN_40.2012.21-3_PR_005 Sending ape-algo image (7096 kB)... Waiting for USB phonet ... Verifying communication to device ... Server application: 1.7.2 Found product: RM-696 rev. 1603 Server implements softupd protocol version 1.8 Image SW version DFL61_HARMATTAN_40.2012.21-3_PR_005 Image moslo not present Image tar skipped Image config skipped Battery level 78 %, continuing. cert-sw ( 1 kB) written. xloader (23 kB) written. secondary (94 kB) written. [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] cmt-2nd (95 kB) written. [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] cmt-algo ( 789 kB) written. kernel (2714 kB) written. [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] cmt-mcusw (6050 kB) written. [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] [f] rootfs [pending 0 % 1024 / 1170162 kB NA ] [-] mmc [pending 0 % 0 / 0 kB NA ] Fetching error list: ======================================== bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed bb5_rdc_cert_read failed mmc: sfdisk returned status 1 mmc: Could not exec 'tune2fs -L rootfs /tmp/sudmmcwJEIRs/internal0p2' mmc: Could not remove mount directory /tmp/sudmmcwJEIRs/mnt: No such file or directory [Pipe 4] Finishing in error state with status 1 ======================================== Sleeping for 15 seconds while device boot up ... |
04-29-2013, 08:53 | #10 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
What was Phone condition before Flashing & now after ? Please specify, so we can assist. BR, ZUBER | |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
