11-08-2012, 16:10 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | help 1110İ bus check flash problem ? NK applet version: 00.20 NK module ready. HTI connected as additional security service. STANDALONE MODE enabled. Please "Scan" or "BUS check" before any operation ... Boot error: CC CC CC 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone help solution ? |
11-08-2012, 16:32 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Check FBus Cable, Possibility of Connection Error between FBus Cable & Phone. Clean all connectivity Terminals for the same. BR, ZUBER |
11-08-2012, 17:23 | #3 (permalink) |
Member: 706822 Status: Offline Thanks Meter: 647 | the same cable other box flash busch check ok the same cable universalbox flash ok jaf box flash ok ufs box flash ok. sample jaf box -->>> MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.400 Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: c9 Loader is ready... P-key nokia module version 01.02 MSID: 846B5BBF68C31FD5003DF178EF MSID decoded: 3E4EBAE90086156AA9000000 FAID: 5A0DD1AE6E150FCDBD217A50 Operation took 0 minutes 9 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013BFFFF... Erasing area: 013C0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 1 minutes 5 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.40ad Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: c9 Loader is ready... P-key nokia module version 01.02 MSID: 84CAF6DDD8EA97631BC7EB7278 MSID decoded: 3E4EBAE90086156AAA000000 FAID: 13910B64FDF7F5B30CC49A14 Operation took 0 minutes 5 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 011E0000 - 011EFFFF... Erasing area: 011F0000 - 0137FFFF... Operation took 0 minutes 26 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 8 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh930_nai6.40ad Booting phone... MCU ID: 0x2031 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x28882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: c9 Loader is ready... P-key nokia module version 01.02 MSID: 84CAF6DDD8EA97631BC7EB7278 MSID decoded: 3E4EBAE90086156AAA000000 FAID: 13910B64FDF7F5B30CC49A14 Operation took 0 minutes 4 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013BFFFF... Operation took 0 minutes 4 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 2 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 2 minutes 19 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-93, Software version: 6.40 IMEI: 352754011643497 Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Done! Powering the phone... Unlocking... IMEI: 352754011643497 ASIC: 2 SW version: 6.40 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\rh93_06.400 Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 01 MCU ID: 0x2031 Algo is ready... P-key nokia module version 01.02 Erasing area: 01140000 - 0115FFFF... Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN MCU ID: 0x2031 Algo is ready... P-key nokia module version 01.02 Erasing area: 01140000 - 0115FFFF... Done! DCT4 unlock counter: 1951 Setting local mode... Reading imei... IMEI/ESN: 352754011643497 Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! |
11-08-2012, 17:51 | #5 (permalink) | |||
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
But the Logs shows Phone having Hardware Issue, If this situation Phone is ON & while Flash process break will make working Phone Dead. Quote:
So as to take precaution & will not Flash, You can check in Hardware, so Phone will be save & not Dead. This Show how you're save with Mxkey Flashing than other Veg Flashers. BR, ZUBER | |||
