Old 06-19-2009, 09:54   #1 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Mx-key rpl dct4 rpl server working fine , test report
DCT4 RPL SERVICE WORKING FINE HERE IS THE LOG
ASIC ID: 0x2201 [UPP_v2.2x]
u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0
FlashID0: 00EC 2268 [Samsung K8S3215ETE] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
u_amd.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518
Performing Flash Authentication ...OK
UEM ID: 0046C99A:2984DA60
ASIC type: 2
UEM Imei: 35226XXXXXXXX
Connecting to server ...OK, Login ...
Hello C0800625, you have 940 credits left.
RPL saved to "C:\mobileEx\3.2\data\backup\RPL\35226XXXXXXXX.RPL "
Programming FLASH Imei ...
FLASH programmed successfully.
Phone Type: RH-64
SW Version: V 7.02 10-12-07 RH-64 (c) NMP
Imei plain: 35226XXXXXXXX-7
Product Code: 0525392
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: MG
Language Pack:
English,Hindi,Marathi
Old 06-19-2009, 10:25   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
@himanshu taldar
U CAN ANY TIME CHECK THE SERVER STATUS AT http://id.mxkey.biz/news.php
HERE IS THE PIC OF THE SERVER STATUS AT 2:52PM INDIAN TIME
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 06-19-2009, 17:41   #3 (permalink)
Member: 549796
Thanks Meter: 56
I can't loggin .........
All time sow " Invalid username or password. "
What is the problem?
Old 06-19-2009, 18:38   #4 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Select mx-key serial no. as username and type the password carefully!
Old 06-19-2009, 22:45   #5 (permalink)
Hitec Wireless's Avatar
Member: 268951
Thanks Meter: 46
How come i dont see on my loger page
DCT4 logs
DCT+ logs
Page is empty when i loged in ???
Hitec
Old 06-20-2009, 04:30   #6 (permalink)
.::PATEL TELECOM::.'s Avatar
Member: 397884
Sonork: 100.1587035
Thanks Meter: 168
yes bro for asic 2,5 is active but
not active for asic 11 and today most of phone coming asic 11 phone
so we will can't make asic 11 phone
br,
patel telecom
Old 06-20-2009, 04:39   #7 (permalink)
palash_c6's Avatar
Member: 650840
Thanks Meter: 622
br,
patel telecom
U R 100% RIGHT
I AM ALSO FACING PROBLEM ON ASIC 11
BR,
P@lash_c6
mx-key hide log rpl dct4 tornado2008 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 01-30-2010 15:42
MX-KEY - FREE DCT4/DCT4+ RPL to all MXKEY users (support all ASICs) MANOLE Service Products News & Updates 0 01-21-2010 11:33
MX-KEY RPL Server Working Fine Now! [Shadab_M] MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 07-09-2009 16:49
unlock e315 solution working fine tested ::.::SOUFIZ GSM::.:: Trident/AGERE Platform 3 12-05-2004 03:44
Page generated in 0.18601 seconds with 10 queries
