11-13-2010, 12:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | help me restore backup imei tried but gets NAND ERROR: pls help me how can i restore backup rpl cos i have erased sucessfully,flashed but imei refused to restore it gives me this NAND ERROR: 00060E4E5043000000000000000000 i have clicked on write imei no success,also restore imei same pls help urgently ............................ RPL: "C:\mobileEx\3.4\data\backup\RPL\356962014 409 79_NPC.rpl" Imei: 35696201440979 APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: FAC9BC43E8797D576EB99CE0C872466798D71F60 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101011103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 10600112B45C00587724CAB365C5B5E30ED27FE7 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: F2C6EBADC86E6189 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,CMT ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 Updating CMT NPC ...OK Programming Status: [NAND ERROR: 00060E4E5043000000000000000000Certificate programmed successfully ! Phone not responding ! |
11-14-2010, 13:55 | #5 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | Quote:
In your case, not write which fw have usated, if have done downgrade, if have saved all BB5 CERTIFICATE, not write which cable use, nothingh, not ask help in this mode and in my pm, and we help you whith very not interess if do u write more particular, this forever. Do u are lucky, just yesterday i was having the similar problem in 1 N70, becouse have ceck in "SW downgrade fix" in Quick Fix of Mx, resultated IMEI 123456....., have immediatly searched the mode for restore IMEI, naturally i have my MX settated in "BB5 SECURE CERTIFICATE VALIDATION" (or similar), when i launch "BUS CHECK", and thanks to this i have restored the BB5 RPL CERTIFICATE, whith your IMEI naturally, easy click in "RESTORE IMEI" TAB. "IMEI REBUILD" in MX, immeditly have open one window whith my "BB5 CERTIFICATE RPL BKP", have select this and have restored my IMEI in one moment, for shure after have inserted the file Rpl from MX RAR FILE where do u have all the RPL W/O NPC DATA, in N70 have only 2 file, but in N95 Rapid Phone do u have alls certificate, also CHANGE CABLE HOW FIRST TIME, after RESTORED YOUR IMEI and for do u to be shure, go whith Self Test or Info Phone, if have Fields of certificate empty, use this RPL W/O NPC and write this, now if want to help to you, here the log of yesterday, but first CHANGE CABLE: RPL: "C:\mobileEx\3.4\data\backup\RPL\35956601460310_NP C.rpl" Imei: 35956601460310 APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 6CE104858896513000492D133A9A3A6E2F820DBE ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2670011777195F51B31C3FBE4550C3685B44293A ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Updating CMT NPC ...OK Certificate programmed successfully ! Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35956601460310-1 Product Code: 0547341 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359566014603101 Version: SIMLOCK SERVER VERSION 58 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF If do u think i was are of help to you, please don't forgot your thanks, BR Max | |
The Following User Says Thank You to .:Ripgsm:. For This Useful Post: |
11-14-2010, 21:53 | #6 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | pls all i have used 3 different f-bus cables but did not work also used ufc cable this did not still solve this problem,to confirm the ufc cable i used it to flash e 65 which uses the same ufc no.3 with n95 and the phone worked well without dying like this n95 which died when i was trying to upgrade it Last edited by tonywireless; 11-14-2010 at 22:01. |
11-14-2010, 23:14 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | go to service then go to quick fix,u will see bb5 nand doungrade bla bla bla.just tick it and click do selected job,after that retry restoring the backup.but next time dont try erasing any sl3 nokia phone.good luck. |
11-15-2010, 13:25 | #8 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | thanks all i have been able to write pm and now it just shows simlock data corrupted but when i press repair simlock or update simlock it does not complete pls what can i do i need a quick answer so i can give the owner the phone he is here with me diaturbing me Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 87298D694E33D4FE0D22397A9A3E6AFEF62E10D8 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1540010639730052CB45C84141C75855E2E7DDE2 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Original Imei: 35294602302... Original Product code: 0564753 Bluetooth ID: 002266A01AE2 WLAN ID: 002266AC4FE2 Phone Type: RM-421 (Nokia N95 8GB) SW Version: V 06wk41v64.19 01-10-09 RM-421 (c) Nokia Imei plain: 35294602302306-0 Language Pack: - not available. SIMLOCK_DATA corrupted! |
11-15-2010, 15:17 | #9 (permalink) | |
br Max | |
11-16-2010, 07:54 | #10 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | help all i am still battling with the n95 problem,after backing up ,erasing ,flashing with eno and normalize filr ,writing backup rpl every thing was okay but sim invalid sd invalid and security test failed ,i repaired the simlock and sd,wrote pm wit sx4 authorization security test still invalid then i wrote mx-key rpl without npc of the same phone and security test is now valid, but now phone shows nokia for about i minute goes white and goes of i dont know what to do again.though there is improvement from just light on keypad to present state but i have done every thing in the book, so i am stuck here.THANKS FOR UR CONCERN IF U HAVE ANY SUGGESTION PLS DO SO WITH URGENCY COS THE OWNER IS WITH ME THREATENING FIRE. |
11-21-2010, 14:54 | #11 (permalink) | |
WRITE and POST ONLY LOGS, br Max | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
