08-14-2010, 10:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Saumlaki-Maluku Tenggara Barat
Member: 424104 Status: Offline Thanks Meter: 45 | help MR manole SECURITY_TEST failed! 5130c SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35604003783329-6 Product Code: 0578115 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356040037833296 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.2.149.60 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.2.149.60 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.2.149.60 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.2.149.60 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.2.149.60 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.2.149.60 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
08-15-2010, 05:13 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | there are many metods to repair this kind err. 1. tick "load RF/BB from server" then press "write" 2. there are have 2 PM Auth ( "PM Auth" and "Super PM Auth" ) if failed in "Super PM Auth" usually i use "PM Auth" then write PM [1] and [309] 3. this can be HWC and CCC in RPL data. must be write as RPL data br, |
08-15-2010, 07:01 | #4 (permalink) |
Member: 424104 Status: Offline Thanks Meter: 45 | Mr Andra Store RFBB to server SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! PMM Auth PM [1] and [309] Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.3.54.35 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.3.54.35 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 182.3.54.35 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Super PM Auth SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.95 03-02-10 RM-495 (c) Nokia Using cached productData[1AD000099CF18956BC24B7E61EB79E6DAF16B91A] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Elapsed: 9.234 s (session timeout out after 3 second) problem located in which ???? plis help me |
08-15-2010, 16:55 | #7 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | SUPERDONGLE repair can be repaired even that SL3 phone but not yet in SIMLOCK REPAIR br, ps:don't forget to make backup full RPL data ( include NPC and SIMLOCK ) |
The Following User Says Thank You to Andra For This Useful Post: |
08-15-2010, 17:05 | #8 (permalink) | |
No Life Poster Join Date: May 2006 Location: lucknow
Member: 275643 Status: Offline Thanks Meter: 360 | Quote:
08-24-2010, 10:55 | #9 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Sri Lanka
Member: 1109931 Status: Offline Sonork: Bongo Thanks Meter: 44 | Showing After Click the Super SD Auth... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 05wk47v60.1 20-03-08 RM-133 (c) Nokia. Using cached productData[0C5002034EA54F5028081DE2B4A8994520E42085] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Elapsed: 3.703 s (session timeout out after 3 second) |
08-25-2010, 05:45 | #11 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Quote:
response from our servers in less then 3 sec. If is more then 3 sec, you get this error. BR, Manole | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
