04-01-2010, 13:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: RSA/HONG KONG/SHENZHEN/BNGKOK Age: 41
Member: 225128 Status: Offline Sonork: 1602598 Thanks Meter: 25 | Help n95 8gig contact the retailer[SOLVED] SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF can sum1 please help a man out with a stey by step solution,i got no pm also so if any1 can upload pm |
04-01-2010, 14:06 | #2 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Sharjah Age: 42
Member: 1158126 Status: Offline Sonork: 100.1589521 Thanks Meter: 475 | Quote:
Repair simlock, then repair sd, and then write sd auth PM, Pm file is here:- Download PM BR | |
04-01-2010, 14:16 | #3 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | 1_mxkey>serves>imei&securty>imei rebuild>repair sd (you will get rpl to repair sim & sd) 2_go to pm >click super sd auth writ pm 1 and 309 and wait 30 second 3_full factory |
Nokia N95 rm159 phone start-up failed contact the retailer [ Solved ] | mariaperezkkk | Cyclonebox | 19 | 03-30-2010 00:04 |
N73 phone start-up failed. contact the retailer[SOLVED] | jutsi | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-28-2010 23:07 |
5700 phone start-up failed contact the retailer[SOLVED] | beo_tech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-07-2010 14:13 |
n73 _phone startup faild Contact the Retailer !!!![SOLVED] | waleed2500 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 01-24-2010 23:02 |
n73 phone start-up failed.contact the retailer [SOLVED] | jak2812 | Cyclonebox | 18 | 09-21-2009 08:08 |
