12-09-2010, 05:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | help problem flashing n900 Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Remove USB cable from device. Turn off the phone Press and hold down key 'u' Connect USB cable between the phone and host PC while still holding down key 'u' When USB cable gets connected it powers the phone and set's it to flashing mode Waiting for phones to boot up ... Flashing completed in 1 min 24.579 s Phone not responding ! when i try to use meamo flasher dont understand the part where i am suppposed to type flasher-3.5.exe -F RX-51_2009SE_1.2009.42-11_PR_COMBINED_MR0_ARM.bin -f -R on command prompt is it constant or it changes with the flash file i am using cos the flash file i downloaded is in exe file and its version 10 i.e Nokia N900 RX-51 Gr.RUS_sw-10.2010.19.1_v4.0 pls help how do i go about this? Last edited by tonywireless; 12-09-2010 at 05:26. |
12-09-2010, 05:27 | #2 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: Made In Venezuela Age: 39
Member: 1044690 Status: Offline Sonork: 100.1617308 Thanks Meter: 56 | Quote:
1: Download and install maemo and copy into maemo installation folder (C: \ Program Files \ maemo \ flasher-3.5) to install the bin file (the downloaded file even navifirm) 2: open maemo flasher 3.5 (you can do from start / all programs / maemo / maemo flasher3.5) "it appears automatically after you install maemo" 3: write exactly maemo open spaces and even the case this command: flasher-3.5-F "exact file name that charge even with the extension it would be. Bin" f-R "enter" typing the exact command would look like: flasher-3.5-F RX-51_2009SE_2.2009.51-1.002_PR_F5_002_ARM.bin-f-R "enter" 4: remove battery, put it back, push button "or" connect the USB cable and now begins to flash software 5: wait the end of flash! maemo flasher 3.5: tablets-dev.nokia.com restricted downloads | |
The Following User Says Thank You to reyfer24 For This Useful Post: |
12-09-2010, 05:42 | #3 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | thanks for ur assistance but this is what i get when i tried it pls help me know what is wrong Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\maemo\flasher-3.5>flasher-3.5-f RX-51_2009SE_10.2010.19-1_PR_CO MBINED_MR0_ARM.bin-f-r 'flasher-3.5-f' is not recognized as an internal or external command, operable program or batch file. C:\Program Files\maemo\flasher-3.5>flasher-3.5-F RX-51_2009SE_10.2010.19-1_PR_CO MBINED_MR0_ARM.bin-f-R 'flasher-3.5-F' is not recognized as an internal or external command, operable program or batch file. C:\Program Files\maemo\flasher-3.5> |
12-09-2010, 05:46 | #4 (permalink) | |
http://forum.gsmhosting.com/vbb/f299...roblem-925841/ | |
12-09-2010, 06:24 | #5 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | i eventually flashed it successfully the error i made was 1 there is supposed to be a space between 3.5 and -5 i.e 3.5 -5 not 3.5-5 2. space between .bin and -f and -R at the end . but now the challenge i am having now is that when i try to perform operation like geting started and opening camera it says it shows not enough memory to to open camera pls help Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_C OMBINED_MR0_ARM.bin -f -R flasher v2.5.2 (Sep 24 2009) SW version in image: RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'kernel', size 1705 kB Version 2.6.28-20101501+0m5 Image 'rootfs', size 173568 kB Version RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Suitable USB device not found, waiting. USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0 105. Found device RX-51, hardware revision 2101 NOLO version 1.4.14 Version of 'sw-release': RX-51_2009SE_10.2010.19-1_PR_MR0 Sending xloader image (14 kB)... 100% (14 of 0 kB, avg. 14 kB/s) Sending secondary image (106 kB)... 100% (106 of 0 kB, avg. 106 kB/s) Flashing bootloader... done. Sending cmt-2nd image (79 kB)... 100% (79 of 0 kB, avg. 79 kB/s) Sending cmt-algo image (507 kB)... 100% (507 of 0 kB, avg. 507 kB/s) Sending cmt-mcusw image (5826 kB)... 100% (5826 of 0 kB, avg. 5826 kB/s) Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... 100% (1705 of 0 kB, avg. 1705 kB/s) Flashing kernel... done. Sending and flashing rootfs image (173568 kB)... 100% (173568 of 0 kB, avg. 173568 kB/s) Finishing flashing... done Erasing CMT: 46%Sending request 0x12 failed: No error C:\Program Files\maemo\flasher-3.5> |
12-09-2010, 07:03 | #7 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | i flashed again and the cmt was flashed successfully but still not enough memory to open camera pls help. log below Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Suitable USB device not found, waiting. USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0 105. Found device RX-51, hardware revision 2101 NOLO version 1.4.14 Version of 'sw-release': RX-51_2009SE_10.2010.19-1_PR_MR0 Sending xloader image (14 kB)... 100% (14 of 0 kB, avg. 14 kB/s) Sending secondary image (106 kB)... 100% (106 of 0 kB, avg. 106 kB/s) Flashing bootloader... done. Sending cmt-2nd image (79 kB)... 100% (79 of 0 kB, avg. 79 kB/s) Sending cmt-algo image (507 kB)... 100% (507 of 0 kB, avg. 507 kB/s) Sending cmt-mcusw image (5826 kB)... 100% (5826 of 0 kB, avg. 5826 kB/s) Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... 100% (1705 of 0 kB, avg. 1705 kB/s) Flashing kernel... done. Sending and flashing rootfs image (173568 kB)... 100% (173568 of 0 kB, avg. 173568 kB/s) Finishing flashing... done Erasing CMT: 46%Sending request 0x12 failed: No error C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_C OMBINED_MR0_ARM.bin -f -R flasher v2.5.2 (Sep 24 2009) SW version in image: RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'kernel', size 1705 kB Version 2.6.28-20101501+0m5 Image 'rootfs', size 173568 kB Version RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Suitable USB device not found, waiting. USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0 105. Found device RX-51, hardware revision 2101 NOLO version 1.4.14 Version of 'sw-release': RX-51_2009SE_10.2010.19-1_PR_MR0 Sending xloader image (14 kB)... 100% (14 of 0 kB, avg. 14 kB/s) Sending secondary image (106 kB)... 100% (106 of 0 kB, avg. 106 kB/s) Flashing bootloader... done. Sending cmt-2nd image (79 kB)... 100% (79 of 0 kB, avg. 79 kB/s) Sending cmt-algo image (507 kB)... 100% (507 of 0 kB, avg. 507 kB/s) Sending cmt-mcusw image (5826 kB)... 100% (5826 of 0 kB, avg. 5826 kB/s) Flashing cmt-mcusw... done. Sending kernel image (1705 kB)... 100% (1705 of 0 kB, avg. 1705 kB/s) Flashing kernel... done. Sending and flashing rootfs image (173568 kB)... 100% (173568 of 0 kB, avg. 173568 kB/s) Finishing flashing... done CMT flashed successfully C:\Program Files\maemo\flasher-3.5> |
12-09-2010, 08:04 | #8 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | after successfully flash n900 now it cannot open camera it says not enough memory to open camera,when i put it on mass storage it no longer shows but it was showing before flashing and before flashing it was working just that after snapping it cannot save it says operation failed,also the dialed numbers could not show when u check them but now they record dailed numbers |
12-09-2010, 09:21 | #9 (permalink) | |
Product Supporter Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 33
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | just use this method i mentioned ... Quote:
use this files and cmd's bro.... first use -f only ... then second time use -r only that's all it's the trick ... | |
12-09-2010, 09:49 | #10 (permalink) | |
Member: 1012165 Status: Offline Thanks Meter: 116 | Quote:
what do i do? Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_C OMBINED_MR0_ARM.bin -R flasher v2.5.2 (Sep 24 2009) SW version in image: RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'kernel', size 1705 kB Version 2.6.28-20101501+0m5 Image 'rootfs', size 173568 kB Version RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2 113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2 210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Suitable USB device not found, waiting. USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0 105. Found device RX-51, hardware revision 2101 NOLO version 1.4.14 Version of 'sw-release': RX-51_2009SE_10.2010.19-1_PR_MR0 C:\Program Files\maemo\flasher-3.5>^A | |
12-09-2010, 10:29 | #11 (permalink) | |
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 | contact me on yahoo .... Quote:
12-10-2010, 09:26 | #12 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | help all after flashing n900 now camera cannot open it writes not enough memory to open camera also when i click on the get started it writes operation temporarily disabled due to low memory, |
12-10-2010, 20:31 | #13 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | pls help i have upgraded the phone to version 20 using this file RX-51_2009SE_20.2010.36-2.002_PR_COMBINED_002_ARM but still yet camera does not open it still says not enough memory what do i do pls |
12-15-2010, 05:49 | #14 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Successful eMMC Flash can solve this problem. I tried in many windows but never succeed. but later i did with Linux. phone is perfectly working with Fresh MMC storage. |
