01-18-2012, 12:27 | #1 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 629860 Status: Offline Thanks Meter: 53 | help urgently.......x6 after flash dont power on.. (ANSWERED) |
01-18-2012, 13:18 | #5 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | Use MX KEY Fire Agent to download latest flash file. For more details please check this http://forum.gsmhosting.com/vbb/f550...losed-1365412/ |
The Following User Says Thank You to mridulnandy For This Useful Post: |
01-18-2012, 13:45 | #9 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | here is your latest file.. MCU- http://nds2.fds-fire.nokia.com/p/d/f...2_prd.core.C00 PPM-http://nds2.fds-fire.nokia.com/p/d/f..._prd.rofs2.V19 PPM-http://nds2.fds-fire.nokia.com/p/d/f...prd.rofs3.fpsx CNT-http://nds2.fds-fire.nokia.com/fdp/i..._U001.uda.fpsx if flashing finish but set only vibrate & no power on then u post your product code here which is printed under the battery. make sure u flash in usb mode. |
01-18-2012, 14:37 | #10 (permalink) |
Member: 629860 Status: Offline Thanks Meter: 53 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085DA9D Using device: HTI, FW ver: 00.50, SN: 0000F505 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Processing MCU file: RM-559_40.0.002_prd.core.C00 [BB5,XSR 1.6] size: 112.91 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08300108E8AD0052401C1B68A669058C1D63F949 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 2.0 size: 0x97D56 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 182.94 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-0B71FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: E00DA77B [RAP Certificate 191 v.1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 5 min 8.938 s Processing PPM file: RM-559_40.0.002_prd.rofs2.V03 [BB5,XSR 1.6] size: 24.01 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08300108E8AD0052401C1B68A669058C1D63F949 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 2.0 size: 0x97D56 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Erase size: 41.87 MB CMT FLASH,MuxOneNAND area [07920000-0A2FFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 7.484 s Processing CNT file: RM-559_40.0.002_001_U315.uda.fpsx [BB5,XSR 1.6] size: 10.27 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08300108E8AD0052401C1B68A669058C1D63F949 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPIDOv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 2.0 size: 0x97D56 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08 Erase size: 312.37 MB CMT FLASH,MuxOneNAND area [0B720000-1EF7FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 32.281 s Total time for flashing process(boot+erase+write) was 7 min 15.985 s and set dont go to test or local mode and dont power on........... |
01-19-2012, 13:09 | #13 (permalink) |
Product Supporter Join Date: Mar 2011 Location: ..::INDIA::.. Andhra Pradesh Age: 41
Member: 1528548 Status: Offline Sonork: 100.1613286(Offline) Thanks Meter: 2,243 | first flash wit letest version next try this solution http://forum.gsmhosting.com/vbb/f609...brate-1396083/ i hope your problem solve....post result |
01-21-2012, 11:17 | #14 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | http://forum.gsmhosting.com/vbb/f550...-1416032/MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C086CBB7 Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.13703(05-01-2012) Processing MCU file: C5F02102_rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2673BC70 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 07700101032E0056507B36E1AF368A9A688ED88F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 19D09CA Verifying communication to device OK. Erase size: 21 MB CMT NOR area [00000000-000006BF] erased in 0.547 s CMT NOR area [000006C0-0001FFFF] erased in 0.500 s CMT NOR area [00040000-000BFFFF] erased in 2.031 s CMT NOR area [000C0000-0013FFFF] erased in 2.219 s CMT NOR area [00140000-0137FFFF] erased in 1 min 14.937 s CMT NOR area [01380000-0151FFFF] erased in 7.266 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 23.547 s Processing PPM file: 18CF28C3_rm495__07.97.ppm_qa [BB5,BB5 ALGORITHM] size: 7.36 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 36.688 s Flash programming ... Programming completed in 34.094 s Processing CNT file: F834BDFE_rm495__07.97.image_qb_blu [BB5,BB5 ALGORITHM] page size: 128 K size: 11.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT NOR area [01DC0000-0215FFFF] erased in 15.578 s CMT NOR area [02160000-03FBFFFF] erased in 2 min 8.297 s Flash programming ... Programming completed in 50.172 s Total time for flashing process(boot+erase+write) was 7 min 38.641 s Waiting for device boot up ... Device found: nmwcdc\Nokia 5130 XPressMusic USB Phonet, PORT_ID: 11BEB775 Verifying communication to device OK. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35267804941234-6 Product Code: 0576625 Battery voltage: 3855 mV, current: 68 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352678049412346 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! |
01-21-2012, 22:23 | #15 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | download files according phone product code. see sticker on phone. flash the phone fully. use market dropdown. never load files manually. example on different rap based phones. ignore any difference logs / version. - if problem still remain, flash the phone once more. - if problem still remain after flash, i have no idea. check phone HW. BR |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
