11-12-2009, 07:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: mobile solution
Member: 638416 Status: Offline Sonork: 100.1591787 Thanks Meter: 1,113 | thes is rpl problem ??? SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35696301898669-4 Product Code: 0539240 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356963018986694 Version: SIMLOCK SERVER VERSION 58 Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F after 3 minite phone off |
SE w395 i want to unlock.....what is this problem? | adamsquall | Universalbox | 2 | 03-29-2010 14:11 |
Before using the simlock RPL, how to check if the superdongle is fine | moulnisky | Cyclonebox | 21 | 01-29-2010 04:39 |
Can't write RPL to 7373 cabel is ok this is software problem pleasse fix this !! !! | wgmmmx | Federal One | 18 | 04-20-2007 10:58 |
