02-06-2010, 06:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 812422 Status: Offline Thanks Meter: 18 | how to fix this by mx key Phone Type: RM-4 SW Version: V 5.62 25-10-04 RM-4 (c) NMP Imei plain: ??????????????-? Product Code: 0513310 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Indonesia,Filipino Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: F12545640A7D5D98 PROFILE_BITS: FAEAC544712D6637 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
02-06-2010, 06:42 | #4 (permalink) |
Member: 812422 Status: Offline Thanks Meter: 18 | here is bus chek brother ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 237E [AMD 29BDS163D,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0058858E:2984DA60 ASIC type: 2 UEM Imei: 33244200096837 Flash Imei: 33244200096837 MasterCode: 4543162765 RPL saved to "C:\mobileEx\3.3\data\backup\33244200096837_BACK.r pl" Phone Type: RM-4 SW Version: V 5.62 25-10-04 RM-4 (c) NMP Imei plain: ??????????????-? Product Code: 0513310 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Indonesia,Filipino Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: F12545640A7D5D98 PROFILE_BITS: FAEAC544712D6637 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
02-06-2010, 06:44 | #5 (permalink) |
02-06-2010, 06:45 | #6 (permalink) |
Junior Member Join Date: Jun 2008 Location: Indonesia
Member: 785213 Status: Offline Thanks Meter: 4 | here is bus chek brother ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 237E [AMD 29BDS163D,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0058858E:2984DA60 ASIC type: 2 UEM Imei: 33244200096837 Flash Imei: 33244200096837 MasterCode: 4543162765 RPL saved to "C:\mobileEx\3.3\data\backup\33244200096837_BA CK.r pl" Phone Type: RM-4 SW Version: V 5.62 25-10-04 RM-4 (c) NMP Imei plain: ??????????????-? Product Code: 0513310 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Indonesia,Filipino Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: F12545640A7D5D98 PROFILE_BITS: FAEAC544712D6637 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! Report Post Reply With Quote Must request RPL |
02-06-2010, 07:00 | #8 (permalink) | |
Member: 812422 Status: Offline Thanks Meter: 18 | Quote:
02-06-2010, 07:52 | #9 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 582669 Status: Offline Sonork: 100.1592908 Thanks Meter: 69 | bro.. contact me i wil help u... [email protected] |
02-07-2010, 13:33 | #13 (permalink) |
Freak Poster Join Date: May 2008 Location: The Time Has Come....
Member: 765331 Status: Offline Thanks Meter: 78 | try this |
02-07-2010, 13:36 | #14 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Code: Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 Can't solve even with Rpl file. HW issue.Change UEM IC. Br, Umair |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
How to Unlock BB5 By Mx-Key (Arabic Video) | Gsm Syria | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 05-17-2010 08:57 |
How to write RPL by mx-key | mizanmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 02-22-2010 19:07 |
How to write RPL by mx-key | mizanmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-15-2010 10:35 |
need solution for this by MX KEY | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-09-2010 12:18 |
how to make rpl by mx-key | solanki telecom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-05-2010 06:41 |
