06-16-2012, 15:55 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: jamnagar(gujarat)india Age: 33
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | How to flash this set or how to solve that? PLEASE TELL ME HOW TO SOLVE THAT I TRY TO FLASH WITH THAT VERSION 6.25 / 6.30 / 6.65 BUT STILL SAME HERE IS LAST ONE 6.25 LOG MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: ******** Using device: HTI, FW ver: 00.50, SN: 000039C7 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.24 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 8804 - 23280001 [ST 58LR128U,128 Mbits] CFI information: Flash settings: 0/64, size: 0x01000000 2 Block regions: 127 x 0x00020000 = 0x00FE0000 4 x 0x00008000 = 0x00020000 EBL ready ! Processing file: rm769_006.250 Downloading item CODE:hw_f3_rm769_r06.250.fls, num block: 3, size: 5.58 MB Erasing area 0x00000000-0x00005FFE ...OK Programming completed in 0.516 s Erasing area 0x00800000-0x00BEFFFE ...OK Programming completed in 1 min 6.015 s Erasing area 0x00C5D000-0x00DFB6FE ...OK Programming completed in 27.078 s Checksum mismatch: Phone calculated 0x3758, software calculated 0x81BE Processing file: rm769_006.25qa Downloading item CUST:hw_f3_rm769_006.25qa.fls, num block: 1, size: 4.76 MB Erasing area 0x00100000-0x005C0DFE ...OK Programming completed in 1 min 21.109 s Checksum verified (0xA325) Processing file: rm7690_nai06.25qa_nlt Downloading item CUST:hw_f3_rm7690_nai06.25qa_nlt.fls, num block: 1, size: 648.20 KB Erasing area 0x00E60000-0x00F013BE ...OK Programming completed in 11.187 s Checksum mismatch: Phone calculated 0xF666, software calculated 0x9400 Total time for flashing process(boot+erase+write) was 5 min 8.172 s |
06-16-2012, 18:54 | #3 (permalink) |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | phone is dead ( water damaged ), means set is dead when customer gives to me,i wash and clean pcb + some glow hit , then try to check on software i try first bus check , its ok then i think its a software problem , thats why i try to flash , but its happens. |
06-16-2012, 19:23 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | read info if possible post log if no try hardware solution the phone is phone is water damaged |
The Following User Says Thank You to ::Evari77:: For This Useful Post: |
06-16-2012, 19:29 | #5 (permalink) | |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | Quote:
dear hardware is clean now , but i think this is a software problem , because u check my first post , its checksum mismatch problem, its only solved by software otherwise set is dead , or one thing is only flash complete but no local mode / test mode or normal mode/ how to read info bro ? | |
06-16-2012, 19:36 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
BR, Zuber Chowdhry | |
06-16-2012, 19:50 | #8 (permalink) | |
bro if u not check there flash not complete bro , please give me some real solution for that this set is nokia 101 rm-769 , not nokia 101 rh-131 , so please give me some solution . | |
06-16-2012, 20:02 | #10 (permalink) |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | here is flash log with HWK IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 921600 FL_ID : FFFFFFFF, Unknown 128Mb MCU FLASH BUNDLE: rm769_006.650 Flash File: hw_f3_rm769_r06.650.fls Erase Area: 0x00000000 - 0x0001FFFE, Erased: 00:01 Write Area: 0x00000000 - 0x00005FFE, Written: 00:00 Erase Area: 0x00800000 - 0x00BFFFFE, Erased: 00:00 Write Area: 0x00800000 - 0x00BEFFFE, Written: 01:12 Erase Area: 0x00C5D000 - 0x00E5FFFE, Erased: 00:19 Write Area: 0x00C5D000 - 0x00DFB6FE, Written: 00:30 Warning, Checksum Mismatch: 2458 > 0F0D PPM FLASH BUNDLE: rm769_006.65mg Flash File: hw_f3_rm769_006.65mg.fls Erase Area: 0x00100000 - 0x007FFFFE, Erased: 01:07 Write Area: 0x00100000 - 0x0060D57E, Written: 01:36 CNT FLASH BUNDLE: rm7690_nai06.65mg_nlt Flash File: hw_f3_rm7690_nai06.65mg_nlt.fls Erase Area: 0x00E60000 - 0x00F5FFFE, Erased: 00:00 Write Area: 0x00E60000 - 0x00F4A13E, Written: 00:17 Warning, Checksum Mismatch: B2DE > C4AB Flashing Done: 05:13 ShutDown Done |
06-16-2012, 20:04 | #11 (permalink) | |
BR, Zuber | |
06-16-2012, 20:33 | #13 (permalink) | |
BR, Zuber | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
06-16-2012, 20:35 | #14 (permalink) |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | ok thanks dear bro here is latest version of 6.65 with mxbox here is log of latest version 6.65 with mxbox with your method MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: Using device: HTI, FW ver: 00.50, SN: Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.24 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0000 0000 - 23280001 [unused/removed] CFI information: Flash settings: 0/64, size: 0x01000000 2 Block regions: 127 x 0x00020000 = 0x00FE0000 4 x 0x00008000 = 0x00020000 EBL ready ! Processing file: rm769_006.650 Downloading item CODE:hw_f3_rm769_r06.650.fls, num block: 3, size: 5.58 MB Erasing area 0x00000000-0x00005FFE ...OK Programming completed in 0.515 s Erasing area 0x00800000-0x00BEFFFE ...OK Programming completed in 1 min 8.531 s Erasing area 0x00C5D000-0x00DFB6FE ...OK Programming completed in 29.032 s Checksum mismatch: Phone calculated 0x0601, software calculated 0x5824 Processing file: rm769_006.65mg Downloading item CUST:hw_f3_rm769_006.65mg.fls, num block: 1, size: 5.06 MB Erasing area 0x00100000-0x0060D57E ...OK Programming completed in 1 min 28.156 s Checksum verified (0xB912) Processing file: rm7690_nai06.65mg_nlt Downloading item CUST:hw_f3_rm7690_nai06.65mg_nlt.fls, num block: 1, size: 939.58 KB Erasing area 0x00E60000-0x00F4A13E ...OK Programming completed in 16.656 s Checksum mismatch: Phone calculated 0x941F, software calculated 0xDEB2 Total time for flashing process(boot+erase+write) was 5 min 30.531 s |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
