11-01-2010, 05:48 | #1 (permalink) |
Registered User Join Date: Aug 2010 Location: EVERY WHERE Age: 38
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | how to remove contact service of 1661 Red (answered) Any rite solution to solve this problem..........plzzzz |
11-01-2010, 05:51 | #2 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,262 | http://forum.gsmhosting.com/vbb/f550...ection-984366/ 5. If you need help, post your problem with most accurate description, post logs and screen shots, phone model and phone status before you used mxkey, also remember to post what version of mxkey software you used and what interface. |
11-01-2010, 06:10 | #4 (permalink) |
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8986(19-10-2010), 1.0.0.14852(19-10-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A57B6FA3BDA66 ASIC type: 11 UEM Imei: 35525003658977 Phone Type: RH-122 SW Version: V 05.01 23-09-09 RH-122 (c) Nokia Imei plain: 35525003658977-0 Product Code: 0572834 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MG Language Pack: - not available. Imei net: 35525003658977 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN LOOK HERE AND REPLY ME WHTS PROBLEM HERE |
11-01-2010, 06:56 | #5 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,262 | while phone is connected to cable and box, set it from local mode to normal mode, and tell me if it does power on normal with it connected and if still shows contact service or not? |
11-01-2010, 19:21 | #8 (permalink) |
Freak Poster Join Date: Aug 2010 Location: ind
Member: 1383260 Status: Offline Thanks Meter: 62 | here is your 100000000% working solution to remove Contact servise Quote: Originally Posted by kush202002 View Post I have 1661 red...i have checked by hard ware or i do software also ....every thing is ok then also its shows contact service..... Any rite solution to solve this problem..........plzzzz here is your 100000000% working solution to remove Contact servise Download |
11-01-2010, 20:30 | #9 (permalink) | |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | Quote:
This is a hardware problem and check hardware. By changing lcd this problem get solved many times. Change lcd and its related components. | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
