02-08-2010, 07:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | SW Version: V 06.20 29-02-08 RM-364 (c) Nokia Imei plain: 35310102145553-9 Product Code: 0559085 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! how to repair this problem................ TEAM HOW TO SOLVE THIS PROBLEM EVEN I USED SD REPAIR AND SUPERDONGLE KEY SAME SECURITY FIELD Last edited by Andra; 02-08-2010 at 10:20. Reason: merger |
02-08-2010, 10:21 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | use searching button is more usefull than spamming our thread 1.[MXKEY - INFO] !!! NEW magic button inside mxkey !!! 2.Just in case if Recovery via Server doesn't work....... 3.[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
The Following User Says Thank You to Andra For This Useful Post: |
02-08-2010, 10:22 | #6 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | even i follow this but same problem i have no back up simlock data pleas how to solve this is you ..... http://forum.gsmhosting.com/vbb/showthread.php?t=920409 |
02-08-2010, 10:23 | #7 (permalink) |
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | even there are 3 option , still help u ????? 1.[MXKEY - INFO] !!! NEW magic button inside mxkey !!! 2.Just in case if Recovery via Server doesn't work....... 3.[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair br, |
how to repair ku990i yellow screen (refreshing) | 4given4gotten | FuriousGold | 1 | 03-29-2010 17:43 |
how to repair security test faild for 6124c-2 | med26 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-28-2010 08:39 |
how to repair security in mx-key | RYKI | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-12-2010 06:25 |
sagem mw930 - how to repair protected fields? | L_DIM2003 | Infineon C16X M51 & ARM7 M52 BASED | 3 | 02-02-2004 11:14 |
