09-23-2009, 07:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | SX4 server DOWN AGAIN????and AGAIN.. server out this time??? i've try two server but same result... Using device: J.A.F, FW ver: 01.B1 APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: DC5AC23A7DB779A19A0B8F40BC72DC0B9B74D0E7 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM1 ID: 00000232 EM2 ID: 00000352 PUBLIC ID: 0B900105E18F4951E0DE01D161C0317410D4F79A ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Original Imei: 35792700880590 Original Product code: 0530336 Bluetooth ID: 0015A0783F98 Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35792700880590-8 Product Code: 0524086 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SECURITY_TEST passed Imei: 357927008805908 Version: SIMLOCK SERVER VERSION 58 Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[mxkey.selfip.biz] ...-Server v2.4 hello 121.54.66.4 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[mxkey.selfip.biz] ...-Server v2.4 hello 121.54.66.4 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request no regards.. |
09-23-2009, 07:50 | #2 (permalink) |
Insane Poster Join Date: May 2005 Location: Malaysia Age: 49
Member: 144914 Status: Offline Thanks Meter: 27 | server is ok.. Phone Type: RM-237 (Nokia 3110c) SW Version: V 06.01 16-01-08 RM-237 (c) Nokia. Imei plain: 35308102568580-4 Product Code: 0514950 VariantId: S Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei: 353081025685804 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[nkrpl.biz] ...MXKEY-Server v2.4 hello 121.122.88.195 SUPERDONGLE auth succeeded! |
The Following User Says Thank You to express For This Useful Post: |
09-23-2009, 10:53 | #3 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | @rico deep try to change your SX-4 Server first ! you can do it right before you click "connect' to any interface, then go to options. select server and click server list. then you select SX-4 Server (there are 2 server available for this operation). and so on...... you can do the rest |
sx4 server down | thungfanglie | Universalbox | 5 | 05-22-2009 19:52 |
Again And Again Server Down...!! | Millo_6 | UID - Box | 0 | 10-10-2007 04:11 |
Twister support's down..again, and again, and again... | cellcenter | Twisterflasher | 2 | 07-14-2006 09:05 |
