Old 06-09-2009, 13:52   #1 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
MobiEx 3.2.1 detected virus
Dear I-Mobile,
I have download new version of MobiEx in support area but detected virus at Mobiex.EXE, the virus New Heur PE Virus by Eset Smart Security antivirus.
Please clarify about this!!!
I was disabled my antivrius n run the program but still problem with WD2 bluetooth flashing always error, please fix the problem.
Thks & Regards,
The Following 2 Users Say Thank You to abellcell For This Useful Post:
Old 06-09-2009, 19:45   #2 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Hi,
At least paste the log please, so i have better clue how to fix.
BR.
The Following User Says Thank You to Alim Hape For This Useful Post:
Old 06-09-2009, 20:13   #3 (permalink)
mr.6630's Avatar
Member: 148424
Sonork: 100.93619
Thanks Meter: 112
Originally Posted by i-mobile View Post
Hi,
BR.
new virsion have a virus
look
br
Old 06-09-2009, 20:32   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
i thinks that sw protection .
make exception
br,
Old 06-09-2009, 20:39   #5 (permalink)
Member: 82073
Thanks Meter: 10
look
br
Seems no problem for my anti virus, I use NAV
The Following User Says Thank You to tenso For This Useful Post:
Old 06-09-2009, 21:36   #6 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Hi,
BR.
i mean log for this problem:
about antivirus, this is not the first issue and users should know that it is not a real virus so making exclusion or add parent folder to trusted zone will always solve the problem.
if you not sure, send the binary/exe to your antivirus support to make sure your self.
BR.
Old 06-10-2009, 03:29   #7 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
hi, I-mobile
I was fix the problem about viruses and was submit to EAV for analize, it is okay.
WD2 flash Bluetooth error, logs:
Nokia 3660 NHL-8 :
Processing file: Nhl83050.8C1
ASIC ID: 0x1081 [UPP_WD2_v3.2,3.2E]
w3_2nd.fia: [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x10D8
FlashID0: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 00000000-007FFFFF
FlashID1: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 02000000-027FFFFF
FlashID2: 0001 267E [AMD 29BDS643HT] page size: 64 K type: NOR area: 04000000-047FFFFF
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: C900 00EA 7001 00EA 7301 00EA 7601 00EA
w3_amd.fia: [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7F10
Performing Flash Authentication ...OK
UEM ID: 005F92A0:2984DA7E
Programming MCU ...
Nhl83050.8C1:
[WD2 BT2][WD2 CBUS BT] size: 18.02 MB
Area [00000000-0000FFFF] erased in 0.547 s
Area [00010000-006FFFFF] erased in 58.125 s
Area [02000000-023FFFFF] erased in 32.875 s
Area [04000000-046CFFFF] erased in 55.484 s
Flash programming ...
BT MCM image (0x21): 0002DD00
Error while programming [00] at 0x00000021, Result: 0200
Flashing terminated with error(s) in 3 min 0.140 s
RX Buffer: 0200000000D172
Ngage QD RH-29 :
Processing file: rh2941.5c1
FlashID0: 0001 007E [AMD 29BDS128J] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 0001 277E [AMD 29BDS064J] page size: 64 K type: NOR area: 02000000-027FFFFF
FlashID2: 0000 0001 [unused/removed]
ExtBUSC: C900 00EA 7001 00EA 7301 00EA FFFF FFFF
UEM ID: 00D15646:2984DA7E
Programming MCU ...
rh2941.5c1:
[WD2 BT2][WD2 CBUS BT] size: 17.62 MB
Area [00000000-0000FFFF] erased in 0.531 s
Area [00010000-00FEFFFF] erased in 1 min 54.890 s
Area [02000000-027FFFFF] erased in 1 min 1.078 s
BT MCM image (0x21): 0002DD94
Flashing terminated with error(s) in 3 min 39.500 s
RX Buffer: 0200000000F172
I flash used other tools, it is okay.
Thks & regards,
Old 06-10-2009, 06:08   #8 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
yes my nod-32 antivirus detect virus of new update
Old 06-10-2009, 07:13   #9 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
Checking for application updates, please WAIT ...
Version from app:
- Executable: 3.0.0.5025
- Library: 1.0.0.4728
winsock error: No data was read because the remote system closed the connection (recv() == 0)
Server temporary unavailable.
mt-box not working in new ver 3.2.1.3,2,1 .::PATEL TELECOM::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-04-2010 10:49
MobiEX 3.2 rev 5.2 WD2 PPM Flashing abellcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 16 10-10-2009 04:53
MobiEX 3.2 rev. 5.2 Unlocking DCT4+ RM-298, RM-340 n RH-112 abellcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 10-09-2009 07:30
Page generated in 0.22773 seconds with 10 queries
