Old 01-27-2012, 16:58   #1 (permalink)
Member: 1715087
Red face MxBox - Phone Not Responding (ANSWERED)
Thank you GSM-Fourm for help on my previous problem.
Background Information:
I am new to the unlocking game, I will be more active on here and helping out other users where I can, Just need a bit of help getting up and running myself.
Currently Own a HTI MXBox (Green Edition)
Ive checked the serial number against faulty builds using the website found on here, all seems to be fine there. assuming ive used the right serial code
I am going to be using the MXBox for Nokia and Blackberry Phones.
I'm running
  • Windows XP Professional SP3 (Fully updated and legal)
  • Comodo Firewall 5.9.22 (Free edition)
  • NOD32 Eset Anitvirus 4.2.71 (Paid Edition)
  • MobileEx 3.5 (Rev1.7) Installed and activated online
I Also Have
  • Z3X Box - Works fine and unlocks Samsung Phones brilliantly
  • XTC Clip - Again, this works fine and unlock HTC Phones brilliantly
The Problem:
I have used three different Nokia's (N900, 2730C, X6)
Each uses the pack that requires you to remove the battery.
Using the Nokia Service Tool Signed v1.25 and selecting the right phone type, (BB5, DCT3, DCT4, ETC) I scan for the phone
Phone not responding, please reset the phone manually then click "OK" to continue
During the scan, the lights flash on the HTI MXBox like it is trying to do something but not a constant blinking.
Tried switched the phone on, or setting it into local mode, I get no response.
Even tried a desperate measure of different USB leads and USB ports on the computer.
I think i have given you all the information I have,
Please, If there is anyone out there
Old 01-28-2012, 06:17   #2 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
you got this error-
its mean you r flashed mobile lower version against mobile's version.
second its appear if mobile have hardware problem.
Old 01-28-2012, 06:24   #3 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
set TMA to 15, then do buscheck and see what happen
what r u trying to do with these phones anyway? unlock? flash? or just want to scan?
br
The Following User Says Thank You to specta For This Useful Post:
Old 01-28-2012, 10:17   #4 (permalink)
Member: 1715087
Originally Posted by ravi mobile View Post
you got this error-
With three mobile phones? I even used my own phone, which i know is fine. As for firmware, I'm not trying to flash the phones. Just use Init Simlock.
Trying to Unlock the sim to use any network. I will try setting TMA to 15. Got to find it first but wish me luck :P
Old 01-28-2012, 10:22   #5 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
tma is used to get the phone into local mode
u need super pc to unlock simlock sl3...
br
Old 01-28-2012, 10:29   #6 (permalink)
Member: 1715087
at this moment in time i would be happy just to get any sort of information from the phone.
MobeilEx won't even bring up the IMEI of the connected phone.
Old 01-28-2012, 10:32   #7 (permalink)
Member: 1715087
Tried Changing TMA to 15 and then done a bus check and i get this
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: ********
Using device: HTI, FW ver: 00.50, SN: ********
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
ERROR: Packet Error(0xAA), code 0xC0000002
Error details:
Bad contact, TX line remains low !
VCC_PH BSI TX RX RX2 CLK
1 0 0 1 1 0
ERROR: *****trap failed!
I have no idea what this means :S :P
for some reason it blanked out the word b.o.o.t.s.t.r.a.p in my quote
Old 01-28-2012, 10:50   #8 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. dont change TMA & post the log of any good working phone now.
Old 01-28-2012, 10:54   #9 (permalink)
GSM_HABIB's Avatar
Member: 1199125
Sonork: 100.1609676
Thanks Meter: 297
i face this problem see this here
Old 01-28-2012, 10:58   #10 (permalink)
Member: 1715087
I don't get a log.
  • Changed TMA back to Auto
  • Clicked Scan
  • Waited
  • Got the same error as before "Phone not responding, please reset the phone manually then click "OK" to continue"
  • Nothing in the Log window.
  • clicked bus check
  • waited
Error Log:
Error details:
1 0 0 1 1 0
ERROR: boot strap failed!
Old 01-28-2012, 11:02   #11 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
I don't get a log.
  • Clicked Scan
  • Waited
  • clicked bus check
  • waited
Error Log:
bro. if the mxbox is in warranty period then replace, it is a box problem 100%.
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 01-28-2012, 11:18   #12 (permalink)
Member: 1715087
zuberchowdhry:
I was starting to think that myself, but I didn't want to send it back without at least trying to solve the problem or having them telling me that I'm not doing it right.
Thank you all for your help, I will try and get it replaced ASAP.
What I don't understand is that only just bought it.
bought HTC Clip, z3x Box, and MXbox all at the same time (3 weeks ago) the other two are fine, just the MXBox seems to be faulty.
The Following User Says Thank You to XiossoiX For This Useful Post:
Old 01-28-2012, 17:08   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
on your logs,
phone is not powered at all.
here is the work around
http://forum.gsmhosting.com/vbb/8053961-post8.html
but yes, send it back to reseller is highly advised
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Page generated in 0.24096 seconds with 9 queries
