Old 04-19-2012, 08:59   #1 (permalink)
Member: 1711671
Thanks Meter: 11
5233 did not boot in normal mode (ANSWERED)
Dear max team wt's this problem plssssssssssss help
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085B468
Using device: USB ROM and HTI, FW ver: 00.50, SN: 00011565
Connection status: OHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
Processing MCU file: RM-625_51.1.002_prd.core.C00
[BB5,XSR 1.6] size: 95.97 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 16179226
CMT SYSTEM ASIC ID: 000000010000022600010006
400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1B3001103FA200526A7DDCA9D2E9E051308BB351
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH:
B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 3 min 50.531 s
Processing PPM file: RM-625_51.1.002_prd.rofs2.V25
[BB5,XSR 1.6] size: 26.50 MB
Erase size: 36.50 MB
CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 1 min 5.921 s
Processing PPM file: RM-625_51.1.002_C01_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 6.16 MB
Erase size: 13 MB
CMT FLASH,MuxOneNAND area [09160000-09E5FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 15.266 s
Processing CNT file: RM625_51.1.002_000_001_U002.uda.fpsx
[BB5,XSR 1.6] size: 14.88 MB
Erase size: 86.12 MB
CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF]
Programming completed in 38.031 s
Total time for flashing process(boot+erase+write) was 6 min 21.687 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 04-19-2012, 16:18   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. post buscheck logs, what was phone status before flashing & any error on buscheck before flashing or you have not done buscheck. see this error in your flashing logs: CERT backup skipped.
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 04-19-2012, 19:03   #3 (permalink)
Member: 772651
Thanks Meter: 1,694
CMT ROOT KEY HASH:
Partitioning....
CMT ADA block sent
CMT KEYS block sent
Erase size: 13 MB
brother check here
because i had same problem and was solved
The Following User Says Thank You to ajit bs For This Useful Post:
Old 04-19-2012, 19:31   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Originally Posted by ajit bs View Post
brother check here
In case you flashed with older version, update to the newest firmware will be solved the problem.
Press "Download" on mobileex before flashing just to find out.
The Following User Says Thank You to gbluez For This Useful Post:
Old 04-20-2012, 11:47   #5 (permalink)
Member: 1711671
Thanks Meter: 11
Dear bus check log below pls help
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
Selected firmware certificate matched.
Original Imei: 00000000000000
Original Product code:
SIMLOCK PA identifier:
[0] PA_SIM
Reading CMT NPC (0xFF bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0xFF bytes).
Reading CMT HWC (0xFF bytes).
Reading CMT R&D (0xFF bytes).
Reading CMT PARTNERC (0x0 bytes).
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
Page generated in 0.27857 seconds with 9 queries
