12-02-2011, 06:24 | #61 (permalink) |
Registered User Join Date: Jun 2011
Member: 1597393 Status: Offline Sonork: 6692766 Thanks Meter: 4 | I tried but fault is very funny.just a data cable fault .i use good one then all is ok |
12-04-2011, 13:25 | #62 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Quote:
I read a lot and I have seen many posts on the change of this transistor BCP-69, but one in particular wrote that could be replaced with any PNP transistor, and tell you that it's the truth. I'm not an electronics expert, so I turned to a technician who repairs TELEVISIONS, radios Itc ... I explained my problem, this person has only answered me not to worry, just 10 minutes I have replaced the transistor BCP-69 with one another and not asked me only 1 cent, returned to the laboratory, like magic, connect a phone running SL3 mode f/bus to HTI/BOX, and after selecting the BOX, I try to make a BUS/CHECK, and immediately see that the phone is seen without any problem, I also do one SCAN/CHECK and after 6 months that this BOX never worked, finally I see walking to high speed, I provide all data and works perfectly on every function. So, friends, changed this transistor BCP-69 with any PNP transistor, and if you are not capable, do like me, you go from an excellent electronic technician and will think him to see the compatibility with a transistor good, I assure you that everything works as it should be. I hope to be of help to those who have problems getting the nokia to MX/BOX, with a charge from nothing now I have my BOX working perfectly. Pardon my English, but i think that you have understand, BR Allumts | |
12-04-2011, 14:00 | #64 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Friend, if you go just a few pages back, you can see many posts that talk about where he is the transistor BCP-69, there are all the pictures with all the ' DATE-SHEET ' of both the BCP transistor-69, what you find opening the BOX, and also other Transistor as the BD-140 itc ... If you read well, I do not understand anything about electronics, so I opened the MX/BOX I saw where is localized and go to a TV technicianI did replace only this transistor with another, now my BOX works perfectly, if you are able to change it, you can use a BD-140 or any other PNP transistor, you'll see that the BOX will work to 101%. I never could use this MX/BOX for 6 months, because I do not read a single nokia phone mode f/bus, it's enough a change of transistors which costs 30 cents. and everything works perfectly. Go back and find pages all figures and DATA-SHEET that you want, if you are able to change it myself, I have solved in 10 minutes and even without spending 1 cent, and I'm not no P. Manager of this BOX, I was interested just that work, I have read, and I solved all problems, Good luck BR Allumts |
The Following User Says Thank You to allumts For This Useful Post: |
12-22-2011, 21:22 | #68 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: iCloud ID Removed Service
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | Quote:
You can search through an online electronic original BCP69... here: http://www.17ic.com/ http://i.6.cn/cvbnm/a3/ea/6c/5d42739...25434.nail.jpg B.R | |
The Following User Says Thank You to LIEREN For This Useful Post: |
12-23-2011, 12:20 | #70 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1187748 Status: Offline Sonork: j.a.f Thanks Meter: 4 | Version from phone: 06.65 Version from file: 07.97 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0858B15 Using device: HTI, FW ver: 00.50, SN: 000074DD Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35422303075410_BA CK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1C20000BCA8D7D56CC5261E76F96875BCF5DE93E ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 15.015 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 17.625 s Processing PPM file: rm495__07.97.ppm_s [BB5,BB5 ALGORITHM] size: 8.02 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 31.796 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 33.890 s Processing CNT file: rm495__07.97.image_s_red [BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 50.625 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 53.016 s Total time for flashing process(boot+erase+write) was 8 min 29.812 s After Flash Processing ... Reseting Factory Values OK. Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35422303075410-5 Product code: 0571951 Battery voltage: 4774 mV, current: 164 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NIMMIIIIRRFF094B2F01, ver: 002.012 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354223030754105 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
12-24-2011, 18:57 | #72 (permalink) |
No Life Poster Join Date: Feb 2010 Location: TURKEY
Member: 1245396 Status: Offline Sonork: BR*BY*PROF*47*47* Thanks Meter: 109 | Everyone does not take the same read and Manole transtrotor have changed in this regard remains sound fake lie does not work, this change Last edited by RIDVAN4747; 12-24-2011 at 19:05. |
12-25-2011, 09:29 | #73 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | I have the same problem, the phone goes into local mode but the hti did not communicate with the phone "when i press scan", but when i press check i got MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C080013A Using device: HTI, FW ver: 00.50, SN: 0000AECD Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 25E00113455E0344A11747A99EE60784425DE035 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Then Nothing!!!! i changed the bcp69 but with same problem, pls help |
12-27-2011, 11:45 | #74 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: IN MY SERVER
Member: 71189 Status: Offline Sonork: 100.1617065 Thanks Meter: 90 | Quote:
12-27-2011, 22:51 | #75 (permalink) |
Insane Poster Join Date: May 2008 Location: mexico
Member: 773102 Status: Offline Thanks Meter: 24 | change for tip32 but not work change bcp69 the nbox old but no work but tip 32 in nbox wokr scan and check whit jaf crack i have 2 mxbox green not work a friend has mxbox with old firmware and works perfect and I with both updated from the 3 I can not be bought at the same time |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
