08-14-2009, 14:35 | #1 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1096586 Status: Offline Thanks Meter: 0 | the latest mxkey have a problem in Windows vista Operating system |
08-14-2009, 15:23 | #4 (permalink) | |
Freak Poster Join Date: May 2009 Location: West Java Flasher
Member: 1035137 Status: Offline Thanks Meter: 72 | Quote:
I'm sorry I use win XP SP2. your current OS is more complicated support for some aplication. because different winscard & ScardSvr command process isue. BTW: try to install driver manually in this folder C:\mobileEx\3.2\data\drivers\card\FT2K\instDrv_std RK200.exe I wish this will help you BR | |
08-14-2009, 15:48 | #6 (permalink) | |
Member: 1096586 Status: Offline Thanks Meter: 0 | Quote:
08-15-2009, 05:13 | #10 (permalink) |
Junior Member Join Date: Dec 2007
Member: 661753 Status: Offline Thanks Meter: 1 | if used in vista, try to change compatibility to windows xp (right click, go to properties --> compatibility), or you can run it as administrator (right click, run as administrator) |
08-15-2009, 10:28 | #13 (permalink) |
Member: 1096608 Status: Offline Thanks Meter: 0 | VISTA version mobileEx_setup_v3.2_rev3.0 system using normal MobileEx_setup_v3.2_rev4.1 update mobileEx_setup_v3.2_rev3.2 and have the same problem, does not recognize the dongle |
pad finder box in window vista | dj_t0t4l | PadFinder box | 2 | 04-22-2008 17:37 |
Can ufsx3+HWK work in Windows Vista ultimate 64bit ?? ?? ?? | wgmmmx | HWK | 2 | 02-22-2008 03:57 |
BB5B0x WoRcK In WINDOWS Vista | dr.deathx | BB5BOX | 0 | 09-19-2007 05:33 |
Can i run UB software in Windows Vista???? | bakhshalvi007 | Universalbox | 3 | 12-09-2006 11:46 |
