02-19-2010, 09:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | loader not responding (0200000000F172) SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000000 PUBLIC ID: 17C0010494806D563C566E480F7884694489A976 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 loader not responding (0200000000F172) |
The Following 2 Users Say Thank You to sunny_luthras99 For This Useful Post: |
04-26-2010, 10:09 | #3 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | This error means yr mobile have some hardware problem so first little take heat on pcb ,ay be yr problem solve. |
The Following User Says Thank You to ravi mobile For This Useful Post: |
09-01-2010, 20:05 | #4 (permalink) |
Junior Member Join Date: Jun 2010 Location: nepal
Member: 1330995 Status: Offline Sonork: 242456 Thanks Meter: 6 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 2C600109E56C034434AA06EEEA0F092005DFFA84 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 loader not responding (0200000000F172) E-52 when flash from mx key---any idea sir --pawan khanal |
The Following User Says Thank You to pawankhanal For This Useful Post: |
06-14-2011, 15:46 | #5 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1476227 Status: Offline Thanks Meter: 0 | MXKEY Serial: [FT SCR2000 0] - C083012E Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 1.5.4.0, NTMP ver: 1.5.4.1 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Processing MCU file: rm217__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.50 MB Supported Ids: 0103192101001101, 010C192101001101 Boot error: 03 00 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Bootstrap failed! Task failed at (08000009)!!! Last RX buffer: 19 D6 51 F5 1D BB 08 27 20 CF 98 54 DF E7 FF AD 17 EB 77 CF 50 B0 C8 89 B2 45 E9 80 C7 C0 E5 57 B4 3D B0 6E 74 D3 A5 7B EA 2B 76 98 57 09 0A F1 7D 75 E6 2F 29 A3 ED 60 EE 5E 0E BD 8D 78 3B 1A 6A 4C 92 CD AF 27 23 CB 8F 77 10 11 96 4F 5F 9E 86 46 FC DE D1 A6 B3 21 9C A8 87 FF E9 B6 92 84 BC CC CB A0 4E 4B DE 12 50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF D3 72 plz help me.......... nokia 6300 shows this error plz plz reply fast |
06-15-2011, 07:51 | #7 (permalink) |
Member: 1476227 Status: Offline Thanks Meter: 0 | MXKEY Serial: [FT SCR2000 0] - C083012E Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 1.5.4.0, NTMP ver: 1.5.4.1 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) Processing MCU file: rm217__07.21.mcusw [BB5,BB5 ALGORITHM] size: 14.50 MB Supported Ids: 0103192101001101, 010C192101001101 Boot error: 03 00 72 00 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Bootstrap failed! nokia 6300 shows this plz help meeeeeeeeeeeee................ |
k800i Bypass loader not responding ! | anz76 | SE Power Clip & Turbo Unlocker | 2 | 01-27-2010 02:39 |
solution for ..loader not responding.. | trio1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 01-22-2010 07:44 |
k800i Bypass loader not responding ! | john_john | SETool2 | 6 | 03-26-2009 01:48 |
T303 cant laod id loader loader not responding | Unlocksupport | SETool2 | 0 | 01-15-2009 14:35 |
"Ram loader not responding to Commands" problem | thonda | Sharp | 0 | 12-05-2006 17:45 |
