04-19-2012, 08:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1711671 Status: Offline Thanks Meter: 11 | 5233 did not boot in normal mode (ANSWERED) MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085B468 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00011565 Connection status: OHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) Processing MCU file: RM-625_51.1.002_prd.core.C00 [BB5,XSR 1.6] size: 95.97 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 16179226 CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B3001103FA200526A7DDCA9D2E9E051308BB351 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 3 min 50.531 s Processing PPM file: RM-625_51.1.002_prd.rofs2.V25 [BB5,XSR 1.6] size: 26.50 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 36.50 MB CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 1 min 5.921 s Processing PPM file: RM-625_51.1.002_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 15.266 s Processing CNT file: RM625_51.1.002_000_001_U002.uda.fpsx [BB5,XSR 1.6] size: 14.88 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 38.031 s Total time for flashing process(boot+erase+write) was 6 min 21.687 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
04-19-2012, 16:18 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. post buscheck logs, what was phone status before flashing & any error on buscheck before flashing or you have not done buscheck. see this error in your flashing logs: CERT backup skipped. |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
04-19-2012, 19:03 | #3 (permalink) | |
No Life Poster Join Date: May 2008
Member: 772651 Status: Offline Thanks Meter: 1,694 | Quote:
brother check here because i had same problem and was solved | |
The Following User Says Thank You to ajit bs For This Useful Post: |
04-19-2012, 19:31 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote: Press "Download" on mobileex before flashing just to find out. | |
The Following User Says Thank You to gbluez For This Useful Post: |
04-20-2012, 11:47 | #5 (permalink) |
Member: 1711671 Status: Offline Thanks Meter: 11 | Dear bus check log below pls help MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085B468 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00011565 Connection status: OHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B3001103FA200526A7DDCA9D2E9E051308BB351 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Selected firmware certificate matched. Original Imei: 00000000000000 Original Product code: SIMLOCK PA identifier: [0] PA_SIM Reading CMT NPC (0xFF bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0xFF bytes). Reading CMT HWC (0xFF bytes). Reading CMT R&D (0xFF bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
