02-04-2010, 18:58 | #1 (permalink) |
Junior Member Join Date: Jan 2010 Location: gsmhosting
Member: 1214415 Status: Offline Sonork: 252732 Thanks Meter: 72 | mobileEx_setup_v3.3_rev1.4 ( with resume ) v3.3 revision 1.4, Public-Release - BB Initial release of BlackBerry Unlocker added to full setup. Works with all BlackBerry models,old and new MEP. MEP database will be updated when new MEP available. more features will be added at future release such as: Flashing, Repair. - NK Added, FREE Universal BB5 SUPERDONGLE Repair works for SLPA and SL20(RAP3Gv2,RAP3Gv3,RAPIDO) Possible to Repair corrupted/erased SD Key which affect in SECURITY_TEST failed and WD enabled. Button located to [IMEI & Security->IMEI rebuild->Repair SD] Added, Universal SUPERDONGLE Authorization Agent to reflect the SD Repair feature SUPER SD/SX4 Auth also works with Original SD and Custom SD made by other tools(Mt-Box,UB,Genie) Repairing SD issue and Doing SX4 Auth has never been easier with MXKEY Button located to [PM->SUPER SD Auth] Added, Single SIMLOCK RPL backup for SL2/SL3 phones Button located to [IMEI & Security->Simlock->Backup SIMLOCK RPL] Added, Apply DSP Patch into PM upload option PM308 from file will be patched instead phone`s PM. Fixed, DCT4 bootloader bug Minor bug fixes ------------------------------------ v3.3 revision 1.3, Public-Release - NK Added, FREE Universal BB5 SIMLOCK RPL Maker works for SLPA and SL20(RAP3Gv2,RAP3Gv3,RAPIDO) Possible to Rebuild/Repair,UNLOCK or LOCK to spesific provider. Fixed, 'Invalid Security Block' bug small GUI changes specially when using Style1 Fixed, BB5 APE flashing bug Added, Manage SIM option Used to Read or Write 'Simlock.bin' file to be used to make customized SIMLOCK RPL Improved, read simlock.bin for SLPA phones. Fixed, HWC write bug Minor bug fixes ------------------------------------ v3.3 revision 1.2, Public-Release - MAIN Improved, interface communication routine (more stable) Fixed, socket communication for some pc(AMD bug?) Fixed, failed re-load module Fixed, registration bug - NK Fixed, NFP extract Fixed, WD2 flashing (UFS) Minor bug fixes ------------------------------------ v3.3 revision 1.1, Public-Release - MAIN Some changes with Check updates mechanism - NK Added, FREE Universal BB5 NCK calc work for SLPA and SL20(including hash 9DDBFCFE6E73CED7D8C6268C8EB85723) Added, BB5 Certificate Validation Usefull to identify SECURITY_TEST problem specially if SUPERDONGLE is valid Button located to [Phone Test->Various] Added, FREE BB5 Certificate Recovery to reflect the CERT validation features This will make restore CCC,HWC or VARIANT by product code from server database. Button located to [IMEI & Security->IMEI rebuild->Recover CERT] Minor bug fixes ------------------------------------ v3.3 revision 1.0, Public-Release #Major update - MAIN Improved, Application Signing system ~ client time will be checked before signatures generation to avoid duplicate error request. ~ date-time issue bug on server side fixed. ~ no messages will be displayed if signatures invalid when working in FREE module(siemens). Added, Server status info on server check ~ ping check removed, so there will be no more firewall problem. Redesigned, Modules Manager page ~ This will make the posibility to update single module at future updates. Check for daily update re-enabled. ~ application will check update once a day and will be displayed in tooltips when new update found. - NK Added, BB5 RAPIDO STN8815(N96) usb flashing(Dead Usb also possible) Fixed, DCT4PLUS ASIC 0x3168 patch unlock and imei changes (2630 v52.70, 2680 v06,80) Fixed, BB5 Flashing (partitioning bug) Fixed, Fast flashing bug when using JAF box. Added, PM308,1 backup on 'BB5 SW downgrade fix' Other modules recompiled for major api changes. ------------------------------------ v3.2 revision 5.6, Public-Release #Minor update - MAIN Improved, Application Signing system ~ Before signing request, sw will set system datetime from ntp server if datetime is not correct. ~ Note: Make sure you have set you computer date,time. ~ The application signing system will not work on the computer with invalid date time ! Removed, Ping on server check - NK Added, Detailed information for each 'Quick Fix' function. ------------------------------------ v3.2 revision 5.5, Private-Release #Minor update - MAIN Added, Application Signing system ~ This is new application security improvement ~ Application will check it signatures when needed, this will check unique card id, application version, and signature datetime validity ~ New created signature will be valid for next 6 month after signing ~ It means that after new update, you might need to 'Sign Application' if the current signature doesnt meet the requirement. Fixed, Windows Vista SP2 compability. - NK Added, BB5 RAPU USB Flashing(spesially for new Flash) Added, Dynamic Camera Configuration upload ~ This features located at 'Phone Test->Camera' Added, TIKU CDMA Product Data (PREPAID_CS_TYPE) fix using server calculation ~ This features will consume credit, how much it will take will be displayed once you logged in using 'Dongle Id' ~ The Service tag is 'DCT4 IMEI+PRODUCT DATA' Added, BB5 RAP3NAND Erase User Area in the 'Quick Fix' tab ~ Usefull to fix BLANK/BLINK or doesnt switch on problem. Added, BB5 PA_SL identification from PASUBTOC Added, New CS type info for newer phone Improved, FAST flash routine ~ SW will keep in flash mode when processing image file, means that it will skip boot and loader upload if config from each file is similiar. Improved, BB5 RPL write ~ SIMLOCK_DATA will be uploaded after NPC write, since new BB5 phone will only accept SIMLOCK_DATA if NPC is valid ! Fixed, BB5 'Security block invalid' bug ------------------------------------ v3.2 revision 5.4, Public-Release #Minor update - MAIN Refixed, Windows Vista & Windows 7 compability. - NK Added, BB5 'Restore SIMLOCK' from '*SIMLOCK.back' or '*.PM' or '*.RPL' ~ The button located at 'IMEI & Security'->'IMEI Rebuild'->'Restore SIMLOCK' Fixed, DCT4 unknown flash bug(BUS check) Fixed, DCT4 CS repair when phone could not go into LOCAL MODE Refixed, DCT4 bootstrap for UFS interface Fake Progressbar for BB5 flash erase reenabled. - VCOM Recompiled PK83.bin for new api compability ------------------------------------ v3.2 revision 5.3, Public-Release #Minor update - MAIN Fixed, Windows Vista & Windows 7 compability. - NK Fixed, BB5 SIMLOCK_DATA/KEY PA_SL3 write Fixed, BB5 RAPU-YAMA phones flashing Fixed, DCT4 flashing bug(DEAD after flash/unlock) Fixed, loading module sometimes failed Improved, Module stability ------------------------------------ v3.2 revision 5.2, Public-Release #Minor update - NK Fixed, WD2(PPM) flashing using UFS ------------------------------------ v3.2 revision 5.1, Private-Release #Minor update - MAIN License #0 needs to be activated(activation is FREE) to load module. - NK Added, DCT4 ASIC 0x3168 standalone 'on the fly' patch for SP UNLOCK and Imei Changes ~ This feature need License #1 to be activated(activation is FREE) Added, Low Level format before CNT write Fixed, Image Download 'in background' hang BB5 Secure Storage Validity now support PA_SL3(unlocked) phones Many Minor bug fixed. ------------------------------------ v3.2 revision 5.0, Public-Release #Minor update - MAIN Added, Dongle License status Info in the Dongle Maintenance Gro***** Added, Update License Button ~ Used to activated custom license of the card which will be used for spesific feature/module To preserve bandwidth, Refill Button will be enabled if Counter < 50 % - NK Added, BB5 PA_SL2 NCK Calculator using security server ~ This will unlock most PA_SL2 phones with protected PM308:1 ~ This feature need License #1 to be activated(activation is FREE) Added, BB5 PA_SL2 Counter Reset Added, SAFE Erase routine while using 'Custom Flash Erase' on the 'Advance Page' ~ SAFE Erase will Protect PM Data from erase specially when doing 'Erase WHOLE flash'. ~ Usefull for recovering a DEAD phone without loosing SIMLOCK DATA Fixed, BB5 Secure Storage Validity for PA_SL3 phones Added, Automatic NPC backup while doing 'Skip SX4 Auth' and 'BB5 SW Downgrade Fix' Minor bug fixed. ------------------------------------ v3.2 revision 4.1, Public-Release #Minor update - NK Fixed, PMM auth bug(application closed) ------------------------------------ v3.2 revision 4.0, Public-Release #Minor update - MAIN Binary will no more run inside Virtual Machine Added, Intrusion detection against code framework manipulation ------------------------------------ v3.2 revision 3.2, Public-Release #Minor update - MAIN Minor bugfix - NK JAF BOX stability and compability improved ~ This will also fix problem with flash dead,random st/hang when using JAF BOX Added, Bus Check routine for 'Nokia USB ROM' ~ Usefull for 'NORMAL' phones which could not connect to USB due to phone lock or something else ~ After sucessfull flash bus check phone will reboot to local mode, so you can do fbus operation such as: reset user code/factory reset Added, Wlan settings in RF/BB tab Fixed, Keypad test start bug Fixed, Sometimes hang after flash erase Wlan settings also included when backing up ProgData ------------------------------------ v3.2 revision 3.1, Private-Release #Minor update - Application core module loader routine changed Private version released to test windows version compability ------------------------------------ v3.2 revision 3.0, Public-Release #Minor update - MAIN Fixed, Random crash on rev 2.2 Added, UI Style option - NK Added, BB5 SW Downgrade in 'Quick Fix' ~ Use this option to patch PM308,1 Downgrade subblock without full flashing. ~ Usefull for phones which 'DEAD' after PM308 write or RPL backup write Added, Skip SX4 Auth Option on 'PM options'. ~ PM options is button with '>' in the PM tab Fixed, Multiple Content selection form vpl files. Fixed, DCT4 Manual Logger error if no service selected Phones image background color now changed to be match with variant Color on market selection ------------------------------------ v3.2 revision 2.2, Public-Release #Patch update - NK Fixed, DCT4 Slow Flashing when using JAF interface. ------------------------------------ v3.2 revision 2.1, Public-Release #Patch update - NK Fixed, UEM req timeout bug on previous release (rev2.0) ------------------------------------ v3.2 revision 2.0, Public-Release #Minor update - MAIN MTBOX boot fixed. Regular minor bugfix - NK Added, BB5 Secure Storage Validation on 'Scan' ; This will validate if SIMLOCK or SUPERDONGLE_KEY is corrupt or not. ; Usefull to determine WD timer or CS issue for BB5 phones. ; Phone with SUPERDONGLE_KEY corrupted, will affect in SX4 auth unsuccessfull or WD problem. ; Phone with SIMLOCK corrupted, will end with CS problem. Added, SIMLOCK2 phones detection (with PM308 protected/read only) ; SIMLOCK2 ('SL2' or 'SIMLOCK2' firmware) phones RPL backup will not work with this phone because of SUPERDONGLE_KEY cannot be restored. Added, ASIC_ID(RAP/OMAP) chip name information Added, flash size information Fixed, BB5 'get address' Fixed, BB5PLUS RPL backup read/write ; Restoring from RPL backup after EEPROM will also restore SUPERDONGLE_KEY so phone will not have WD timer issue. Forced to change phone mode to TEST_MODE when doing factory reset and Self Test. Added, DCT4 Manual Logger ------------------------------------ v3.2 revision 1.4, Private-Release #Patch update - MAIN Improved, Scard api (spesially for ccid reader compability) - NK Improved, BB5 RPL upload/write ;Specially for phone which support SL2+SL3 simlock, by default old protocol will be used and it its failed new protocol automatically be used. ------------------------------------ v3.2 revision 1.3, Public-Release #Patch update - MAIN Improved, privilege adjustment ; hopefully will solve not starts problem ?! ; So far tested with XP XP2(OEM), Vista Ultimate(NOT OEM), Vista Ultimate SP1 (OEM) - NK BB5 SIMLOCK SL3 Structure upload from RPL backup added. ------------------------------------ v3.2 revision 1.2, Public-Release #Patch update - NK Added, Support for BB5 SIMLOCK SL3 Structure upload Fixed, WD2 CBUS Loader parse for correct BT flashing ------------------------------------ v3.2 revision 1.1, Public-Release #Patch update - NK Fixed, Online Logger not shown when 'Imei changes' disabled. Fixed, BB5 Restore Imei+Write RPL ------------------------------------ v3.2 revision 1.0, Public-Release #Major Update - MAIN Added, UI Localization ;languages selectable from 'quote' menu ;locale files stored to 'locale\*.xml' directory ;added, Chinese (Simplified) language for test (translated using Google Translate, so am sure its not 100% correct), unicode enabled. ;full localization might be added at the future Added, balloon Tips stored to locale files Fixed, Application not opened in some PC caused by not previlege account (specially XP SP3 and Vista SP1) List of loaded drivers version are now displayed at start up Server list are now selectable Added, posibility to play custom sound on error/finish Added, Card Serial Port drivers ;allow to use serial(comport) based reader for the card Added, 'Nokia USB ROM' virtual device to be used for BB5 USB DEAD PHONE flashing Fixed, Connect<->Disconnect bug (appl. crash) - VCOM Small change in UI Changed, PK-83 binary to support new drivers - CCS Fixed, nkser(6088,6066,7088) driver handling when flashing stop at the middle of process - NK Added, BB5 USB Flashing ; Supported loaders RAP3Gv2+APE(external loader), RAP3GV3+APE, RAP3GV3 NON APE+DEAD FLASH, RAPIDO NON APE+DEAD FLASH, RAPIDO +APE, RAPIDO (RAP3NAND) NON APE+DEAD FLASH. ; Version check mechanism is possible when flashing NON DEAD phone ; LANGUAGE only option also posible for fast and safe phone update Added, Multiple version of flash update/loaders ; selectable from 'quote' menu 'Config->Directory' ; Newer phones might need newer flash loader, by default is '8.6.1.31560' Fixed, BB5PLUS RAPIDO SL2 spunlock Added, Pinout image for UFC based cable (press small button near phone image) ; pinout images are stored at 'data\image\pinout' directory Multiple Data Package directory are now possible (usefull when working with Multi-OS PC) Added, 'Force WHOLE flash' on erase(Advance Page) to allow RAP flash full erase (Last chance, if NPC reset still not work to revive DEAD/BLINK Phone) Added, PP file read Added, Phonebook/Contacts backup and restore (Phone Settings->Selection:User Settings) Removed, Host setting (please use 'select server' from Main|Server List page) - SIEM Siemens module recompiled for new api compability ------------------------------------ v3.2 final bug-fixed, Public-Release - NK DCT4 RPL server host changed, to fix timeout in some country Improved, DCT4PLUS "on the fly" unlock patch and imei patch Added, AMS loader v. 8.49.19.36652 to the installer minor bug fixes - VCOM Fixed, Active-X initialization to fix rx no respond in some pc ------------------------------------ v3.2 FINAL, Public-Release - MAIN Improved Server communication Added, Support area access Goto Options->Server->Server List (make selection on 'Support') then Goto Support button will enabled - NK Added, Standalone BB5PLUS SL2 No TP Unlocker PM Auth checkbox also added for some phones which need SUPERDONGLE to be authorized while writing PM120 and PM308 Added, DCT4PLUS "on the fly" imei changes Improved, DCT4PLUS "on the fly" unlock patch (+new security also supported) Improved, PM read and write (if field not checked will be skipped) To Open PM, you can now Drag And Drop PM file to listbox Fixed, BB5 loaders bug for new phones Fixed, image download Fixed, BB5 auto set RX2 Fixed, DCT4PLUS Online Logger bug minor bug fixes - VCOM Fixed, PK-83 binary for MXKEY REV 2.0 compability Siemens FREE module recompiled for new api & library compability. ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++ ++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++ v3.1 Beta16 , Public-Release - MAIN Removed old card protocol(MXKEY REV 1.X/ROCKEY6), for this release only MXKEY REV 2.X card supported - NK Fixed, loader issue Added, single phones setting (VPP,RX2, Fast checkbox now saved to config for each phone) Added, BB5 No TP Unlocker, Dejan RAP3GV2 unlocker removed. supported HASH: BAF3A9C3DBFA8454937DB77F2B8852B1,E9EFF4BFAA5393217 CA6B17755FC3E14,CAEEBB65D3C48E6DC73B49DC5063A2EE,9 A28E119033B91D14D22838C86D0D53C supported ROM: 273F6D55DFAAF68F,191EC665DFAAF68F,F28A211FCEA7B19D ,A8C1D6713E691FF8,F2C6EBADC86E6189,F28A211FAC901AE E(untested),4B9B75103E691FF8(untested) Fixed, `highlight market` bug minor bug fixes - CCS Improved, communication. Dead phones full flashing now working ================================================== ================================== v3.0 Beta15 RC, Public-Release - MAIN help file updated minor bug fixes - NK DCTL/LINDA fully implemented with Custom erase to fix old 9210i CS problem Fixed, Image DL (server communication protocol changed) Fixed, BB5 custom certificate backup Fixed, New PP files manual upload Improved, SUPERDONGLE auth (show the detailed error msg) Improved, User code reset for BB5 phones minor bug fixes ------------------------------------ v3.0 Beta14 RC, Public-Release - HW MXKEY LiTE dongle firmware version 00.14 released (Improvement dongle check, to avoid CARD BLOCKED) update using SW build beta14 only. - NK Added RAP NAND option in manual erase Added, CRC check before flashing if declared in definition files(BB5) Image DL in background mode improved (CRC check) minor bug fixes ------------------------------------ v3.0 Beta13 RC, Public-Release - MAIN Fixed, MXKEY (ROCKEY6) dongle detection. - NK Image DL in background mode now possible Added 'skip Restore' patch for DCT4PLUS unlock Fixed, PPM2 image parsing minor bug fixes - VCOM Fixed, registration popup Added, PK-83 Dongle emulation (you need to install CCS3 Tool first before it works) ------------------------------------ v3.0 Beta12 RC, Public-Release - MAIN Fixed, dongle registration popup - NK DCT3 fully implemented Fixed, BB5 flash for new phones some improvement and minor bug fixes - CCS Fixed, 6066/88 flash ------------------------------------ v3.0 Beta11 RC, Public-Release - MAIN Improved, dongle communication routine Fixed, Self Update - NK MTBOX DCT4 flash supported. Improved, DCT4&BB5 Online Logger Improved, RX2 auto enabled Added, Simple hint "detailed" BB selftests Added, DCT4PLUS (asic type 11) phone UEM read Fixed, PP extract for DP2.0 phones - CCS Added, Forced RX queue for better handle of dead phone flashing Fixed, Emergency mode Image DL enabled - OTHER Added, Latest mxLogger client(v1.4b) in setup ------------------------------------ v3.0 Beta10a RC, Public-Release - NK Fixed, BB5 Online Logger Fixed, BB5 RAP NAND (with RX2 enabled) flashing Added, Full BB5 RPL backup for new phone (SIMLOCK+SIMLOCK_KEY,WMDRM_PD) Added, BB5 user code reset(blocked counter) and status, will not lose user data. Improved DCT4 Asic 11 Online Logger (Imei challenge issue) Added, auto create folder option on configuration window Fixed, DP2.0 folder listing ------------------------------------ v3.0 Beta10 RC, Public-Release - MAIN Added, Support forum and homepage menu (News) - NK Added, Image DL button (direct image download from support based on product code, currently for BB5 products only !) Implemented, RX2 loader support (UFS FW v28 only !!!). Implemented, Show detailed options in configuration window Added, Auto select Gen when "Scan" product in configuration window Added, Auto set RX2 for BB5 in configuration window Added, market highlight for easy market choise in configuration window Added, Auto set RX2 for BB5 in configuration window Added, BB5 CNT page size detection for auto CNT convertion Added, Skip if not empty option Added, Manual PP write file Added, BB5 MMC and SD card content flashing Added, BB5 verify NPC option on write RPL Added, BB5 skip spesific section on write RPL Added, BB5 skip (certificate) erase option on write RPL Added, BB5 Reset NPC Added, BB5 online logger client (instant !!!) Added, BB5 RPL write on RX2 enabled phones Fixed, DCT4 MM flash handling Added, DCT4 imei OTP/UEM read via FBUS for non CUI phones. Added, Latest DCT4PLUS ASIC11 sp unlock patch method(Patch on the fly) Added, DCT4PLUS ASIC11 online logger client Added, extended GSM/WCDMA band type set Improved, BB5 (RAP/CMT) NAND flash handling Improved, Flash chip info. device page size and type now displayed. Improved, DCT4PLUS ASIC11 ask read + manual IMEI/ESN input when UEM damaged Changed, 'Browse' to Directory setting in configuration window - CCS Improved, QCOM protocol for faster flashing Improved, Dead phone flashing handle Added, Phone code read for 6088,7088 phone Added, Image DL button (direct image download from support) Fixed, Userarea backup/restore ------------------------------------ v3.0 Beta9 RC, Public-Release - MAIN Improved, Check for updates (more control to updates) Implemented, Online News(add RSS feeds and forum news) Implemented, Options to enabled/disabled spesific module - NK MTBOX Partially supported(FBUS function) Improved, DCT4 boot Improved, Auto phone detection (always "Scan phone" or "Bus check" before any operation!) Improved, CDMA phones compability Improved, Keyboard test map (now possible to test all keys including communicator series) Added, Various tests (Camera,IR,MMC,SIM,USB) Added, Band & System mode control Added, CDMA NVD (Pri) management (under Phone Settings tab) Added, CDMA CS product type read Added, RF/BB PM backup/restore Added, BB5 CNT 128 K convertion Added, COMBOFLASH detection Fixed, DCT4 write RPL (add DATA1/2 only options) Fixed, BB5 Custom erase Fixed, DCT4 APE flash(better error handler) Improved, DCT4 SP unlock routine Improved, CDMA tuning (SET,CAL and PANEL data are now readed and written correctly) Redesigned, PMM, Phone Settings, CDMA tune & Quick Fix page(under services tab) Reconstructed, BB5 'Dejan K' unlocker Introduced, DCT4 read flash works for Asic type 2 phones only (check 'Phoenix format' for writable output) - just for test ! Introduced, DCT4 Non Volatile Data(NVD) management (in development, not finished yet) - CCS Added, ARMPRG/Bootloader manual select to handle 'dead' phones Fixed, Invalid hex error while flashing Improved, Phone explorer routine and ui ------------------------------------ v3.0 Beta8, Public-Release - MAIN Fixed, "Check For Updates" bug Fixed, UFS baud problem (DCT4 erase issue?) - NK Fixed, DCT4PLUS non patch unlock (1600,1110i) Added, Automatically save RPL backup on "Bus Check" for DCT4 Fixed, DCT4 Erase ! (hopefully fixes this common issue, tested on 3 different PCs Intel/AMD based) - VCOM Fixed, Incorrect registration popup ------------------------------------ v3.0 Beta7, Public-Release. Whats NEW: - [MAIN] Added, "Dont Show This Again" checkbox of UFS FW update confirmation dialog Improved, Check For update routine will allow to update module separately on future updates - [CCS] Added, New Module CCS "Foxconn PST"(NK CDMA ODM QUALCOMM) Features: * Flashing using HEX/ CBB (Bundle Files) * Normal Flashing or Emergency Mode (*+5+POWER) supported * Flashing Emulation * Security Code Read/Write * SPC read/write * LCD contrast Read/Write * Reset File System (PRI) * Userdata Backup/Restore * EFS File Explorer * And soon - [VCOM] Revised, VCOM module - [NK] Added, Patch SIMLOCK flashing option + SKip SW patch on Init Simlock (1650 bug) Improved, Flash erase routine Added, UEM WD test Added, Verify UEM option on DCT4 RPL write - [SIEM] Fixed, SGOLD baudrate issue and other minor. Version Information: Main: » mobileEx.exe, version: 3.0.0.889 » mobileEx.dll, version: 1.0.0.1144 Modules: » ccs.dll, library version: 1.0.0.103, module version: 1.00 ß » nk.dll, library version: 1.0.0.897, module version: 1.00 ß7 » siem.dll, library version: 1.0.0.293, module version: 1.01 ß » vcom.dll, library version: 1.0.0.664, module version: 1.02 ƒ Required Dongle revision: MXKEY, FW ver: 00.11 MXKEY LiTE, FW ver: 00.13 *) ß = BETA ƒ = FINAL ------------------------------------ v3.0 Beta6, Public-Release. Whats NEW: - JAF BOX fully supported. - Added, Flash Emulation mode(to verify flash files, will not write to the phone) - Added, Support for BB5 RAPIDO phones(RAP NAND flash handle) - Added, Easy IMEI restore(Automaticaly search for backup from '\data\backup\RPL\' folder if available) - Added, DCT4 Mass Memory device(NAND) flashing support - Added, UFS FW V 2.8 update dialog if needed(required for RAPIDO phones handle) - Added, UFS Driver update dialog if 'NO CONNECTION' - Fixed, N-GAGE Adsp flashing bug(CRC error=Contact retailer). - Fixed, DCT4 Online IMEI Logger (ESN issues) - Fixed, WD2 boot (increasing boot timeout) - Fixed, User Code changes - Fixed, BT MCM image upload - Fixed, Erase whole flash routine - Fixed, Reset DATA1 (WD2 bug) - Fixed, TIKU flashing with huge image header stoped - Fixed, DCT4 UCP 128k convertion(2865 issue) - Fixed, DCT4 PLUS SpUnlock bug on old models - Removed, Joker module from installer - Added, SIEMENS Tool(EGOLD, SGOLD) module. and other minor. Required: MXKEY, FW ver: 00.11 MXKEY LiTE, FW ver: 00.13 ------------------------------------ v3.0 Beta5, Public-Release. Whats NEW: New MXKEY LiTE firmware introduced, FW ver: 00.13 - Added, JAF FBUS protocol (Flashing bus not implemented yet) - Added, Component version info on load. - Fixed, Erase whole flash bug on multi flash chip phones. - Fixed, BT flush after firmware update. - Fixed, BB5RPL decryption fail when write RPL. - Added, Product code auto selection on "Scan" and other minor. Note: for MXKEY LiTE dongle user, you need to "Update FW" first. ------------------------------------ v3.0 Beta4, Public-Release. Whats NEW: - re-constructed & improved, DCT4PLUS unlock patch - RELOCK now possible, also support 1200/1208 all version(click "No" when you asked to restore flash block) - re-constructed, DCT4 CNT 64->128k convertion. - Added, support for new product profile type(BB5,DCT4PLUS). - Fixed, crash (application closed) on VCOM module. - Improved, FBUS scan (will change phone mode if needed) - Fixed, PM write function (BB5 RF & BB parameters bug) and other minor. ------------------------------------ v3.0 Beta3, Public-Release. Whats NEW: - re-constructed, CDMA Tuning. - re-constructed, Quick repair page (BT repair, LCD reset, etc). - improved, Online Updater. - added, CDMA NFP folder to model selection. and other minor. ------------------------------------ v3.0 Beta2, Public-Release. Whats NEW: Almost all elements are new, the most important part of this ßeta was that it was finally recoded from scratch. Not implemented yet: - JAF interface support - DCT3/L function - DCT4PLUS unlock patch - BB5 generic unlock - and some other. This brand new exe will supports MXKEY and MXKEY LiTE What is MXKEY LiTE? its new dongle for mobileEx, SmartCard based. What about future support about MXKEY? We released MXKEY LiTE for *******r satisfaction. MXKEY LiTE will be cheaper, and thats why we call it "Lite". MXKEY will be fully supported as MXKEY LiTE, note that there was no differences between MXKEY and the LiTE version. Unimplemented features will be added as soon as possible. while that, you could also request feature MXKEY LiTE quick driver instalation: !!! Do NOT install Smartcard reader before installing drivers. goto "C:\mobileEx\3.0\data\drivers" then click "instdrv.exe" to install the Reader driver. This is PCSC ISO7816 compatible reader, you could also use any PCSC compatible reader to work with the card. ----------------------------------- v3.0 Beta, Pre-Release. Published to beta-testers. ####################### Supported BB5 SUPERDONGLE RPL: All Available phones in the market based on RAP3Gv2,RAP3Gv3 and RAPIDO with SLPA and SL20 and SL3 SIMLOCK version ####################### Supported BB5 SIMLOCK RPL: All Available phones in the market based on RAP3Gv2,RAP3Gv3 and RAPIDO with SLPA and SL20 SIMLOCK version ####################### Supported BB5 NCK Code Reader: All Available phones in the market based on RAP3Gv2,RAP3Gv3 and RAPIDO with SLPA and SL20 SIMLOCK version ####################### Supported BB5 No TP Unlock(OLD METHOD): RAP3GV2: -6630 (RM-1)* -6680 (RM-36)* -6681 (RM-57)* -6682 (RM-58) -N70 (RM-84)* -N70-5 (RM-99) -N71 (RM-67) -N90 (RM-42)* -N91-1 (RM-43) -N91-8GB (RM-43)* -N91-5 (RM-158)* -N93 (RM-55) RAP3GV3: ;Relock also supported -3109c (RM-274) -3110c (RM-237) -3250 (RM-38) -3500c (RM-272) -3500cb (RM-273) -5200 (RM-174) -5200b (RM-181) -5300 (RM-146)* -5300b (RM-147) -5500 (RM-86) -5700 (RM-230) -5700 (RM-302) -6085 (RM-198) -6086 (RM-188) -6086b (RM-260) -6125 (RM-178) -6126/6133 (RM-126) -6131 (RM-115) -6131 NFC (RM-216) -6136 (RM-199) -6151 (RM-200) -6233 (RM-145)* -6234 (RM-123)* -6280/6288 (RM-78)* -6290 (RM-176) -6300 (RM-217)* -6300b (RM-222) -7370 (RM-70) -7373 (RM-209) -7390 (RM-140) -8600 (RM-164) -E50 (RM-170) -E50 (RM-171) -E50 (RM-172) -E61 (RM-89) -E61i (RM-227) -E62 (RM-88) -E65 (RM-208) -N73-1 (RM-133)* -N73-5 (RM-132) -N75 (RM-128) -N76 (RM-135) -N76 (RM-149) -N77 (RM-194) -N80-1 (RM-92) -N80-3 (RM-91) -N92 (RM-100) PA_SL2: -3120C (RM-364)* -3555 (RM-277) -3555b (RM-257) -5310 (RM-303)* -5310b (RM-304) -5610 (RM-279) -5610d-1(RM-242) -6263 (RM-207) -6300i (RM-337) -6301 (RM-322) -6500s (RM-240)* -6500c (RM-265)* -6555 (RM-289) -7500 (RM-249) -7900 (RM-264) -8800 (RM-165) exception(Not supported, new security[PA_SL3]): -3600s(RM-352) V56.26 -5310 (RM-303) V58.58 -6500c (RM-265) V59.45 -6500s (RM-240) V59.60 -6300 (RM-217) V57.20 RAPIDO: -N95 (RM-159)* -N95 (RM-245) -N95 (RM-160) -E90 (RA-6) PA_SL2: -6110 (RM-122) -6120c (RM-243)* -6121c (RM-308) -6124c (RM-422) -6210 (RM-367) -6220c (RM-328) -6290 (RM-176) -6650 (RM-400) -E51 (RM-244)* -E66 (RM-343) -E71 (RM-346) -N79 (RM-349) -N95-2 8GB (RM-320) PA_SL2 with Protected PM(NCK Read): -E75 (RM-412)* -N96 (RM-247)* -N85 (RM-335)* -5800 (RM-356)* -6220c (RM-328)* ####################### Supported DCT4PLUS Patch Unlock: -1110i (RH-93)* -1112 (RH-93)* -2310 (RM-189)* -2610 (RM-189)* -1650 (RH-86)* -1200 (RH-99)* -1208 (RM-205) -1209 (RM-105)* -2680 (RH-392) -5000d (RM-362)* -2600c (RM-340)* -2626 (RM-291)* -2630 (RM-298)* -2670 (RM-258)* -1680c (RM-394)* -2330c (RM-512)* -2323c (RM-543)* -2720a (RM-519)* -7100s (RM-438)* *) tested. ####################### # Supported MEP(BlackBerry Unlock) ####################### MEP-12579-001 MEP-11139-001 MEP-06424-001 MEP-11139-004 MEP-11139-006 MEP-11139-003 MEP-11139-002 MEP-04104-003 MEP-11139-005 MEP-05277-001 MEP-14260-001 MEP-06899-001 MEP-06814-002 MEP-06893-001 MEP-04598-004 MEP-10129-001 MEP-06811-003 MEP-06810-002 MEP-06530-002 MEP-06530-001 MEP-06813-001 MEP-12579-002 MEP-07705-002 MEP-06259-002 MEP-08318-001 MEP-08395-001 MEP-13988-001 MEP-09004-001 MEP-08448-001 MEP-12186-001 MEP-13928-001 MEP-06041-003 MEP-06068-001 MEP-06041-001 MEP-07484-002 MEP-08209-002 MEP-09747-001 MEP-04104-005 MEP-07722-003 MEP-04546-001 MEP-07722-001 MEP-04938-002 MEP-04938-001 MEP-09783-002 MEP-09821-001 MEP-07722-002 MEP-07484-001 MEP-06849-001 MEP-06529-001 MEP-06529-002 MEP-04103-001 MEP-11246-001 MEP-14150-001 MEP-06813-002 MEP-15326-001 MEP-15326-002 MEP-14074-001 MEP-10073-001 MEP-06812-003 MEP-06899-002 MEP-08918-001 MEP-11016-001 MEP-12978-001 MEP-12622-002 MEP-11414-002 MEP-10129-002 MEP-06814-004 MEP-06814-001 MEP-13188-001 MEP-13710-001 MEP-11414-001 MEP-06423-001 MEP-04598-005 MEP-11534-002 MEP-06259-003 MEP-08209-001 MEP-07754-001 MEP-09938-001 MEP-06068-002 MEP-06424-002 MEP-09293-001 MEP-08448-002 MEP-10129-003 MEP-08881-001 MEP-08882-001 MEP-15343-001 MEP-07321-002 MEP-09690-001 MEP-11534-004 MEP-14052-001 MEP-09149-001 MEP-12209-003 MEP-07484-003 MEP-06041-006 MEP-12209-004 MEP-09667-001 MEP-04103-002 MEP-07484-004 MEP-14896-001 MEP-09783-003 MEP-04626-001 MEP-12599-003 MEP-06041-005 MEP-07723-001 MEP-14260-002 MEP-04104-006 MEP-12565-001 MEP-04626-002 MEP-15159-001 MEP-05277-004 MEP-12488-001 MEP-08589-001 MEP-09917-001 MEP-06849-002 MEP-16352-001 MEP-14896-002 MEP-09070-001 MEP-16472-001 MEP-04104-007 MEP-07705-003 MEP-05277-002 MEP-06812-001 MEP-04598-003 MEP-12980-002 MEP-12980-001 MEP-16419-001 MEP-16272-002 MEP-06041-007 MEP-04104-004 MEP-17232-001 MEP-13990-001 MEP-11534-005 MEP-14896-003 MEP-17490-001 MEP-16826-001 MEP-06041-008 MEP-11534-006 MEP-06041-004 MEP-07484-005 MEP-18637-001 MEP-10129-004 MEP-19322-003 MEP-11534-007 MEP-17568-002 MEP-07723-003 MEP-09625-001 MEP-04103-004 MEP-12907-002 MEP-20454-001 MEP-09292-002 MEP-07484-006 MEP-20099-002 MEP-14896-004 MEP-20669-001 MEP-13188-002 MEP-19877-001 MEP-08209-003 MEP-07484-007 MEP-15159-002 MEP-20099-004 MEP-21545-001 MEP-14896-005 MEP-20166-001 MEP-18601-001 MEP-13928-002 MEP-22793-001 MEP-14074-002 MEP-20099-009 MEP-23361-001 MEP-09821-002 MEP-11534-008 MEP-24124-001 MEP-13188-006 MEP-07723-004 MEP-24723-002 MEP-24723-001 MEP-10129-005 MEP-16272-003 MEP-24667-001 MEP-24660-001 MEP-12209-006 MEP-24409-002 MEP-13188-007 MEP-07723-005 MEP-12209-007 MEP-26594-001 MEP-14052-002 MEP-26900-003 MEP-05277-005 MEP-06041-009 MEP-13188-010 MEP-12209-008 MEP-27488-001 MEP-28364-001 MEP-16272-005 MEP-09292-003 MEP-28240-002 MEP-09292-001 MEP-28555-001 MEP-09292-004 MEP-13188-008 MEP-27501-003 MEP-14074-003 MEP-11246-002 MEP-29318-001 |
The Following 16 Users Say Thank You to gsmfamily.com For This Useful Post: |
06-01-2010, 17:57 | #4 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073 Status: Offline Thanks Meter: 2,181 | 6210s unlock done Quote:
06-18-2010, 05:22 | #5 (permalink) |
No Life Poster Join Date: Aug 2009 Location: .:::Sri Lanka:::. posts: 9999 Age: 33
Member: 1093564 Status: Offline Thanks Meter: 326 | help plz n79 not unlocked Imei net: 356387025****** Version: SIMLOCK SERVER Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F Backup already exist. Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Product: V ICPR72_08w44.1 24-11-08 RM-348 (c) Nokia ApeCoreSw: 11.049 Reading Simlock info ... |
How to write rpl dct4 phone with mobileEx_setup_v3.3_rev1.7 exe | Shantobhai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-25-2010 13:36 |
Mxkey Software Update mobileEx_setup_v3.3_rev1.4 | mkamal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-06-2010 13:08 |
mobileEx_setup_v3.3_rev1.4 Setup Download Link | sagtel | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-03-2010 14:07 |
problem with mobileEx_setup_v3.3_rev1.1 | igor_06 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 01-17-2010 10:10 |
