Old 12-10-2009, 22:10   #1 (permalink)
Member: 581597
Module activated with limited support!
mx_key show this message when h start the programe
Old 12-11-2009, 02:05   #2 (permalink)
Member: 1150025
Thanks Meter: 70
I have already encountered this problem with the JAF BOX, but for UFS it works fine.
peace
Old 12-12-2009, 09:30   #3 (permalink)
mrnazam's Avatar
Member: 1001269
Thanks Meter: 226
my problem same plz anyone can telk me ?
Old 12-12-2009, 10:00   #4 (permalink)
Member: 1150025
Thanks Meter: 70
mate, if you are using JAF box it is normal that MODULE ACTIVATED WITH LIMITED SUPPORT will appear, but not with the UFS.
Old 12-12-2009, 13:06   #5 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
bro dont worry its just a information and msg about jaf box only.............................................. ..................ok
ak
Old 12-12-2009, 13:07   #6 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
ak
Old 12-12-2009, 14:21   #7 (permalink)
Member: 581597
sir >>> when i do bus check whith n73 work ok. its say <DEVICE IQ ERROR:ACCESS IS DENIED(CODE:5)
What does it mean.???
Old 12-12-2009, 14:28   #8 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
bro first use good modifeid 7 pin cable................
ak
Old 12-12-2009, 14:44   #9 (permalink)
Member: 581597
ak
SIR cable WORKS GOOD WITH JAF+P-KEY TESTED 100%
Old 12-12-2009, 14:50   #10 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
bro first chek any other n73.........if same problem then
uninstall mxkey setup and also delete folder of mx key from drive c: and install it again and select foler of flash fils......then chek it...............
ak
Old 12-14-2009, 02:00   #11 (permalink)
Member: 581597
mr ak: i d0 every thing > the same proplem...
box error :0000,please reconnect the box and try again!
Error opening !
with another phone 6300 ok
that the box working ok with p-key vista
Module activated with limited support! with ver: 3.3:1.6 Unicom MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-14-2010 09:07
Module activated with limited support Deepakranasaria MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 12-11-2009 08:36
Module activated with limited support! ak72342 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 12-11-2009 08:28
Module activated with limited support! adnanskyland MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 10-18-2009 11:44
Module activated with limited support! R@ZIB-BD MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 09-01-2009 10:14
Page generated in 0.21470 seconds with 9 queries
