01-17-2011, 07:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Live pakistan Age: 46
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | mr.manole mxkey server is down plz solve this problem urjent..........plzz (ANSWERED) |
The Following User Says Thank You to umardarz For This Useful Post: |
01-17-2011, 07:57 | #6 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00523773A3BDA66 ASIC type: 11 UEM Imei: 35291202422325 [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) Last edited by ...:::::NP™:::::...; 01-17-2011 at 08:04. |
01-17-2011, 08:09 | #7 (permalink) |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | I am also victim. Yes server go down. Mx-key team please fix this problem [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) |
01-17-2011, 08:45 | #10 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Again & More Server Down .........................? ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00100CA8:2984DA60 ASIC type: 2 UEM Imei: 35698001746283 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00100CA8:2984DA60 ASIC type: 2 UEM Imei: 35698001746283 [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) |
01-17-2011, 08:53 | #11 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bangledashe ctg
Member: 884989 Status: Offline Sonork: 12000 Thanks Meter: 157 | ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00841830A3BDA66 ASIC type: 11 UEM Imei: 35679902905347 [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) Again & More Server Down .........................? Mx-key team please fix this problem............. |
02-25-2011, 06:33 | #14 (permalink) |
Freak Poster Join Date: Dec 2008 Location: India, jharkhand, lohardaga
Member: 931237 Status: Offline Sonork: 51812884 Thanks Meter: 98 | mxkey Server is down ASIC ID: 0x2031 [UPP_4M ver: 3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00481170:29xxxxxx ASIC type: 2 UEM Imei: 3598xxxxxxxxx [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) Socket error (10051): Network is unreachable [InternalErrorFault] Server is down for maintenance, please try again later (case id=0xCB03) mxkey team plzzzzzzzz solve this problem |
02-25-2011, 07:55 | #15 (permalink) |
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
