02-04-2010, 19:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | Mx key giving me more problems than pkey why does my MXKEY not pickup my 6230 i get this message at the end Performing Flash Authentication and it stops there, goes no further ? i use PKEY and same cables and PKEY picks it up, have look below.... BUS chek MXKEY....................... Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11893, Date: 26-01-2010 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0039 [Samsung KEE00E00CM Eija NAND,64 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ... PKEY................. MCU ID: 0x1052 FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... |
The Following User Says Thank You to LOCKED4EVER For This Useful Post: |
02-05-2010, 13:15 | #4 (permalink) | |
Member: 950386 Status: Offline Thanks Meter: 114 | Quote:
Very much doubt this is a cable problem as cable works with PKEY. Evidence of this is above. My guess is iv bought mxkey to early and should have bought the mt-box (when pkey support stopped) as mx key is still a new born baby and the only way problems are gona be fixed with mxkey is by people reporting problems. | |
02-05-2010, 13:29 | #5 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 326941 Status: Offline Thanks Meter: 16 | Quote:
02-05-2010, 14:15 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Quote:
money with it. Then go and buy mtbox, no one stop you, and be happy with their system of credits, special system for rob you of much money possible. We are aware of MXKEY bugs, they will be fixed. We do not consider them so important since you can make same job with free jaf software. BR, Manole | |
The Following 8 Users Say Thank You to MANOLE For This Useful Post: |
mx key gives error with ufs | jignesh269 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-15-2010 14:47 |
mx key give me this error with all phone why? | neeraj1st | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-12-2010 13:38 |
mx key give the 1202 unlocking all users are waiting | diljankhan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-13-2009 15:54 |
What is MX Key??? Give me Details?? | nofear99 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 11-14-2009 06:37 |
Some sugesstion for mx-key to make it better than the best:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 06-12-2009 02:44 |
