Old 01-05-2010, 07:52   #1 (permalink)
Member: 1196390
Thanks Meter: 5
3110c flashing error
my dead 3110c flashing time show error.ist i do bus check................
log here
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11446, Date: 25-11-2009
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0EF0000BB4767C5640FA5CF638FFCF301E81BA19
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
Original Imei: 35681502180742
Original Product code: 0550573
Bluetooth ID: 0022FCF8AFE5
after bus check i flashed...............log here
Processing file: rm237__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate ...OK
Total erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 1.015 s
CMT NOR area [000006C0-0001FFFF] erased in 0.078 s
CMT NOR area [00020000-0007FFFF] erased in 1.063 s
CMT NOR area [00080000-000DFFFF] erased in 0.141 s
CMT NOR area [00100000-001FFFFF] erased in 0.281 s
CMT NOR area [00200000-0031FFFF] erased in 0.297 s
CMT NOR area [00320000-0105FFFF] erased in 3.094 s
CMT NOR area [01060000-01067FFF] erased in 0.093 s
CMT NOR area [01068000-0107FFFF] erased in 0.079 s
Flash programming ...
Error while programming [00] at 0xFFFFFFFF, Result: 0000
Flashing terminated with error(s) in 40.250 s
RX Buffer: B37
plz expert tell me where is fault (software or hardware)
thanks in advance
Old 01-05-2010, 08:00   #2 (permalink)
Member: 521190
Thanks Meter: 140
yes I am same problem facing too.
Old 01-05-2010, 08:00   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
can be :
- cable
- Hardware -> flash IC.
and some reason.
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 01-05-2010, 08:01   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
what problem do u have ?
can u add log info here ?
br,
Old 01-05-2010, 08:03   #5 (permalink)
Member: 757799
Thanks Meter: 782
try usb flashing........
Old 01-05-2010, 09:31   #6 (permalink)
Member: 878934
Thanks Meter: 13
try flashing whit JAF, via usb ("dead usb")
The Following User Says Thank You to CrbL For This Useful Post:
Old 01-05-2010, 09:43   #7 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
also have same problem and not solved with usb.
Old 01-05-2010, 09:52   #8 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
Dear its cmt flash ic problem Little bit rehot than try flash
Old 01-07-2010, 17:52   #9 (permalink)
Member: 878934
Thanks Meter: 13
"also have same problem and not solved with usb. " ---then u should check for hardware fault
i agree whit AZEEM
Old 01-07-2010, 21:36   #10 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
flash the phone with usb.
Old 01-08-2010, 04:18   #11 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
No hw problem.Mx-key can't flash 3110c due to some bug tested on atleast 10 set.flashed succesfully by mt.Hope in next update problem solved.
and in 1100 user code reset fails on every set.
Old 01-08-2010, 22:48   #12 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
past i already give explanation about this.
phone auto select in RX2 option.
but if cable not have RX2 pin,software will be stop/error
so,
check cable / use other cable.
check box interface
br,
3110c flashing error Jabir27 Nokia Base Band 5 ( BB-5 ) 10 03-06-2009 07:07
3110c flashing error shadowdex Universalbox 1 05-06-2008 16:20
3110c flash error ... please help hamid123 Universalbox 4 09-14-2007 15:26
Page generated in 0.21644 seconds with 9 queries
