Old 02-06-2011, 12:37   #1 (permalink)
***MALIK***'s Avatar
Member: 556396
Sonork: 100.1609417
Thanks Meter: 363
Thumbs down nokia 1616 after falash no power on
nokia 1616 after falash no power on here is log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU ID: A200341100 [X-GOLD 110]
Sending Primary Boot Loader ...OK
Changing baudrate to: 921600
Sending Secondary Boot Loader ...OK
BootloaderString: SE0_091125 F11
Boot mode: CC
EBL version: 10.13, Default_RAM_Bootloader
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing CODE:hw_f11_rh125_r06.200.fls from file rh125_006.200
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming ...
Programming completed in 38.016 s
Erasing area 0x00C60000-0x00EAFFFE ...OK
Programming ...
Programming completed in 37.687 s
Erasing area 0x00FFC000-0x00FFFFFE ...OK
Programming ...
Programming completed in 0.032 s
Checksum failed
Processing CUST:hw_f11_rh125_006.20ia.fls from file rh125_006.20ia
Erasing area 0x00210000-0x0045FFFE ...OK
Programming ...
Programming completed in 33.094 s
Checksum failed
Processing CUST:hw_f11_rh1250_nai06.20ia.fls from file rh1250_nai06.20ia
Erasing area 0x00EB0000-0x00F7FFFE ...OK
Programming ...
Programming completed in 5.860 s
Checksum failed
Flashing completed in 3 min 39.250 s
After Flash Processing ...
Phone Type: RH-125
SW Version: V 06.20 01-12-10 RH-125 (c) Nokia
Imei plain: 35377504931316-6
Product Code: 0588617
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
- not available.
Imei net: 35377504931316
Version:
Provider: GSM Test Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
any sugetion,idea
Old 02-06-2011, 12:39   #2 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,091
Boot mode: CC
Programming ...
Programming ...
Programming ...
Checksum failed
Programming ...
Checksum failed
Programming ...
Checksum failed
Phone Type: RH-125
Ppm Id: IA
Language Pack:
- not available.
Version:
Counter: 0/3, 0/10
any sugetion,idea
already have post bro!
http://forum.gsmhosting.com/vbb/f550...wered-1103959/
Old 02-06-2011, 12:43   #3 (permalink)
syed jewel's Avatar
Member: 1067276
Sonork: 100.1591989
Thanks Meter: 654
bro chenge lcd 100% solve your problem tast by me
Old 02-07-2011, 05:01   #4 (permalink)
Member: 556396
Sonork: 100.1609417
Thanks Meter: 363
where is mood and ...................
answer the question,
why set dead after falash with mx key
Old 02-07-2011, 05:26   #5 (permalink)
Member: 894556
Thanks Meter: 22
try to short bsi and ground then power it on if the phone powered check the bsi lines
Old 02-07-2011, 05:26   #6 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
use mx key
check selftest
send logo
i show lcd fail
change lcd 100% pro solve
Old 02-07-2011, 05:44   #7 (permalink)
Member: 1511075
try to short ground and bsi using led..
if powered on... it is bsi line faults...
anj make a jumper to it in r2082
Old 02-07-2011, 05:52   #8 (permalink)
Member: 1134037
Thanks Meter: 18
Flash it the low version then power became on
Old 02-07-2011, 05:53   #9 (permalink)
Member: 556396
Sonork: 100.1609417
Thanks Meter: 363
also check lcd, and change
but still dead,
Boot mode: CC
Programming ...
Programming ...
Programming ...
Checksum failed
Programming ...
Checksum failed
Programming ...
Checksum failed
Phone Type: RH-125
Ppm Id: IA
Language Pack:
- not available.
Version:
Counter: 0/3, 0/10
Old 02-07-2011, 06:43   #10 (permalink)
syed jewel's Avatar
Member: 1067276
Sonork: 100.1591989
Thanks Meter: 654
pls send self test info bro
Old 02-07-2011, 07:52   #11 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
solved your problem in this solution
credits goes to MR. ATO of gsmsandwich.com.ph
original link:GSMSandwich ©
Old 02-07-2011, 08:26   #12 (permalink)
RIJAS2010's Avatar
Member: 1417101
Sonork: 100.1619006
Thanks Meter: 157
just post your phone info
Page generated in 0.21655 seconds with 9 queries
