02-06-2011, 12:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: https://www.facebook.com/group
Member: 556396 Status: Offline Sonork: 100.1609417 Thanks Meter: 363 | nokia 1616 after falash no power on Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r06.200.fls from file rh125_006.200 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 38.016 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 37.687 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.032 s Checksum failed Processing CUST:hw_f11_rh125_006.20ia.fls from file rh125_006.20ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 33.094 s Checksum failed Processing CUST:hw_f11_rh1250_nai06.20ia.fls from file rh1250_nai06.20ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 5.860 s Checksum failed Flashing completed in 3 min 39.250 s After Flash Processing ... Phone Type: RH-125 SW Version: V 06.20 01-12-10 RH-125 (c) Nokia Imei plain: 35377504931316-6 Product Code: 0588617 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35377504931316 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN any sugetion,idea |
02-06-2011, 12:39 | #2 (permalink) | |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Quote:
already have post bro! http://forum.gsmhosting.com/vbb/f550...wered-1103959/ | |
02-07-2011, 05:53 | #9 (permalink) |
Member: 556396 Status: Offline Sonork: 100.1609417 Thanks Meter: 363 | also check lcd, and change but still dead, Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r06.200.fls from file rh125_006.200 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 38.016 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 37.687 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.032 s Checksum failed Processing CUST:hw_f11_rh125_006.20ia.fls from file rh125_006.20ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 33.094 s Checksum failed Processing CUST:hw_f11_rh1250_nai06.20ia.fls from file rh1250_nai06.20ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 5.860 s Checksum failed Flashing completed in 3 min 39.250 s After Flash Processing ... Phone Type: RH-125 SW Version: V 06.20 01-12-10 RH-125 (c) Nokia Imei plain: 35377504931316-6 Product Code: 0588617 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35377504931316 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
02-07-2011, 07:52 | #11 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | solved your problem in this solution credits goes to MR. ATO of gsmsandwich.com.ph original link:GSMSandwich © |
