08-30-2010, 08:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | Mx key's dct4+ rpl server is back in motion ! Code: ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00829D72:DA3BDA66 ASIC type: 11 UEM Imei: 3595330xxxxxxx SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\359533xxxxxxxx.RPL" ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00829D72:DA3BDA66 Programming FLASH Imei ...failed warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RH-99 SW Version: V 5.23 10-03-08 RH-99 (c) NMP Imei plain: 3xxxxxxxxxxxx-8 Product Code: 0546861 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Language Pack: - not available. Imei net: 35953xxxxxxxxxx Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! |
New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-23-1999 20:24 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
