04-10-2010, 07:43 | #1 (permalink) |
Insane Poster Join Date: May 2009 Location: 中国
Member: 1028010 Status: Offline Thanks Meter: 16 | MX Nokia Service Tool 1.0.0.12676 error Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D1187A:3B8ADA60 ASIC type: 11 UEM Imei: 35679102974988 Flash Imei: 35679102974988 MasterCode: 5344554017 RPL saved to "E:\仪器主控\主控\mobileEx\3.3\data\backup\3567910297498 8_1270881974_BACK.rpl" Phone Type: RM-438 (Nokia 7100s) SW Version: V 06.31 24-03-09 RM-438 (c) Nokia Imei plain: 35679102974988-8 Imei OTP: 35679102974988 Product Code: 0574754 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: UA Language Pack: - not available. TimeStamp: 2009-04-02T04:43:21Z SW Version: 06.31 Variant Version: 003 ProductProfile: RM438_0574754_06.31_003.spr Simlock: 0574754_simlock.sim Imei net: 35679102974988 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555035555 SIMLOCK_DATA corrupted! RPL saved to "E:\仪器主控\主控\mobileEx\3.3\data\backup\3567910297498 8_1270881981_BACK.RPL" Update nokia module ?Nokia Service Tool Version from module: 1.0.0.12095 Version from server: 1.0.0.12676 Partial update available. GET: mobileEx.lib OK GET: productapiconfiguration.xml OK GET: nk.mx OK Update completed, please restart application. System: ? OS version: 5.1.2600.5781 Service Pack 3 - 中文(中国) Main: ? mobileEx.exe, version: 3.0.0.7632, date: 13-02-2010 ? mobileEx.lib, version: 1.0.0.7931, date: 21-03-2010 Modules: ? bb.mx, library version: 1.0.0.422, module version: 1.01, date: 12-02-2010 ? ccs.mx, library version: 1.0.0.1262, module version: 1.02, date: 21-01-2010 ? nk.mx, library version: 1.0.0.12676, module version: 1.09, date: 21-03-2010 ? siem.mx, library version: 1.0.0.293, module version: 1.01 B, date: 23-11-2009 ? vcom.mx, library version: 1.0.0.1312, module version: 1.03, date: 21-01-2010 Loaded Drivers: ? SarasSoft UFS2XX, version: 3.4.16.0, date: 8-3-2009 ? FTDI FTDIBUS, version: 2.0.0.0, date: 5-19-2006 ? Microsoft Serial, version: 5.1.2600.0, date: 7-1-2001 ? FTDI FTSER2K, version: 2.0.0.0, date: 5-19-2006 MX 3.3 1.6 Update nokia module BUS Check LOG: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! MX 3.3 1.7F BUS Check LOG: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! Why? |
04-10-2010, 07:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Update to latest version - RapidShare: 1-CLICK Web hosting - Easy Filehosting |
04-10-2010, 08:00 | #4 (permalink) | |
Member: 1028010 Status: Offline Thanks Meter: 16 | Quote:
Is 3.3 1.7 F error | |
04-11-2010, 02:03 | #10 (permalink) | |
Not UFS - 3 box,JAF BOX is wrong Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Error flash config request! No matter what kind of box, as long as 1.0.0.12676 update Tool Service Nokia is wrong!!! Thank you SRINIBAS solutions | |
04-23-2010, 07:44 | #11 (permalink) |
Member: 1028010 Status: Offline Thanks Meter: 16 | v3.3 revision 1.8+fix BUS CHECK 7100s PASS LOG: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00D1187A:3B8ADA60 ASIC type: 11 UEM Imei: 35679102974988 Flash Imei: 35679102974988 MasterCode: 5344554017 RPL saved to "E:\仪器主控\主控\mobileEx\3.3\data\backup\3567910297498 8_BACK.rpl" Phone Type: RM-438 (Nokia 7100s) SW Version: V 06.31 24-03-09 RM-438 (c) Nokia Imei plain: 35679102974988-8 Imei OTP: 35679102974988 Product Code: 0574754 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: QA Language Pack: - not available. TimeStamp: 2009-04-02T04:43:21Z SW Version: 06.31 Variant Version: 003 ProductProfile: RM438_0574754_06.31_003.spr Simlock: 0574754_simlock.sim Imei net: 35679102974988 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
