11-11-2011, 00:36 | #17 (permalink) | |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | Quote:
damaged sim card or even a damaged box. This is the order for this steps: 1. Drivers - be sure are correctly installed. 2. Test with card inside a reader - take card out from mxbox and put in a reader (pkey type) and see if software will see your card. 3. Chk if your sim card reader from MXBOX do not have the pins damaged. (here you can tell me if you have PCB V3 or PCB V4) * There was few pcs stock from first PCB V3 what factory used against my advice some low quality sim card readers what can have pins damaged when you insert sim card. Let me know if you did this and none of this true. BR, Manole | |
11-11-2011, 22:58 | #18 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | mobileEx 3.5 (rev1.5) works fine if I put card in pkey in one usb port and other usb the hti-box. hti works ok with this setup but if I put back the card into the hti box mobileEx cannot see card, the pins look fine and board is version 4. there is also a driver problem with card, I believe card reader electronics faulty in my hti. |
11-11-2011, 23:41 | #19 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | I have exactly the same problem, hti only work with pkey redear in hti box card not working......but because i have all others great tools, i have only try to install HTI , i have check that is a great ****, till today, my HTY is full of DUST.....but don´t mind i like to give charaty to manoles brothers..... PS: i have HTI garbage version 3 |
The Following User Says Thank You to DUSKnenixs For This Useful Post: |
11-12-2011, 00:17 | #22 (permalink) |
Member: 5169 Status: Offline Thanks Meter: 684 | I'll put my HTI in the microwave about 20 minutes on maximum temperature, lets see the results ... just kiding eheheeh just check this is common problem for windows xp... Question: Why do you sell chinese garbage to people of europe? When all is made on europe, have more quality.... |
11-16-2011, 21:52 | #24 (permalink) | |
Member: 60899 Status: Offline Thanks Meter: 792 | Quote:
The Following User Says Thank You to mrfixit For This Useful Post: |
11-17-2011, 02:15 | #25 (permalink) | |
As you can see, problems come from users who do not install correctly. There can be problems with hardware also, even big companies have % of return. You will never see here all users who use good to report this, you will see only who have problems to report and this is normal. Is not my fault we have so many customers all the world, this is the reason you see more reports in this forum. BR, Manole | |
The Following User Says Thank You to MANOLE For This Useful Post: |
11-17-2011, 02:49 | #26 (permalink) |
Freak Poster Join Date: Jul 2009 Location: Inside Softwa®e™
Member: 1084363 Status: Offline Thanks Meter: 109 | hi.., this is the easiest way to check if the problem..is in your box reader.. just open your device manager...click on smart cards.. you should see that your hti smart card is driven by WinUsb.. if not then it's just a simple driver issue that users usually faced... and to solved this just update your smart card driver... if yes you can see that your hti smart card driver is already driven by Win Usb.. you should contact your reseller...because your box ix covered with 6 months warranty |
The Following User Says Thank You to -=Meltech09=- For This Useful Post: |
12-03-2011, 04:53 | #27 (permalink) |
Freak Poster Join Date: Jun 2008 Location: "NEAR YOU"
Member: 785142 Status: Offline Sonork: 100.1606160 Thanks Meter: 177 | the easiest way, is install jaf setup 1.98.62 that's it, that's what i did, to my "MXKEY NO SECURITY DONGLE DETECTED" & your problem will be solved 100%... |
Security Code | dESiRE! | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 05-13-2011 22:17 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
dongle.exe | Aldrin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-22-2000 04:40 |
I will finished Dongle for Nokia WinTesla | MyKy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-14-1999 22:47 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
